Window Squeeks
Old Jun 3, 2010 | 02:14 PM
govertime's Avatar
Window Squeeks
Has anybody had any issues with their window squeaking?
I have tinted windows and cleaned them well. There doesn't seem to be any debris (pebbles/sand/grit) in the window seal/channel. There aren't any scratches on the tint indicating any debris either.
When I first noticed it a few months ago, I sprayed silicone lubricant into the channel (learned to use this after having to replace the motor on an older honda accord) but that didn't work since the channel/seal is felt-lined (or some other bristly fabric) and not just rubber like most older cars. In fact, after I sprayed silicone, it added another weirder squealing noise which seemed to go away as the silicone wore off the bristly felt-like channel.
My guess is I'm going to have to remove the door panel and grease a window regulator or something before the motor dies from any resistance it may be encountering. Anybody have to do this?
Hopefully there is an easier solution... it's starting to drive me nuts.
Thanks for any input!
Old Jun 3, 2010 | 02:19 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Found this thread the other day, it might help
https://mbworld.org/forums/clk-class...dow-seals.html
Old Jun 3, 2010 | 02:31 PM
govertime's Avatar
Thanks Dynomite.
I'm hesitant applying Pedro's Ice Wax (which is apparently intended for bicycle chains) but I might dab on some of that super expensive MB sunroof grease I recently picked up for my panorama roof.
I'm curious what exactly was done in TSB P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit. Anybody have this TSB done for their C230?
Anybody have to have their window realigned, or window regulator greased?
