cabin air filter, please help
Old Jul 1, 2010 | 11:51 AM
pdvng_mb's Avatar
C240 2003 4matic
Hi guys, I bought the cabin air filter from autohausaz.com. I got the two piece air filter and couldn't figure out where the filter is. I have extensively search and still got no results. THIS IS NOT the air filter above the battery. I took out the screw below the dash from both passenger and driver side and didn't find any filter there either. Any help will be appreciated and any picture would be nice. Thanks.
I have a 2003 C240 with 70K. Just did the oil change and replaced engine air filter.
Old Jul 1, 2010 | 12:20 PM
samaritrey's Avatar
Super Moderator
THE C350
In your car the only filter is above the battery so i guess your filter housing got lost. the 2 piece filter is only for certain cars like mine.
Old Jul 1, 2010 | 12:30 PM
pdvng_mb's Avatar
C240 2003 4matic
Thanks smaritrey, the filter above the battery is still there. I thought that there are more than 1 cabin air filter. This sucks, I just wasted 70 bucks.
Old Jul 1, 2010 | 01:02 PM
samaritrey's Avatar
Super Moderator
THE C350
yeah that sucks btw where are you located?
Old Jul 1, 2010 | 01:15 PM
e1000's Avatar
a quarter mile at a time
Correct, depending on year, there is a second set of filters in the car, below and behind the glove compartment. I believe the newer w203's just have the one above the battery
Old Jul 1, 2010 | 01:34 PM
samaritrey's Avatar
Super Moderator
THE C350
Yeah the 01-03 c320's i know came with them and the 02-03 c32's came with them. after 03 or 04 it was stopped and only more expensive models have the charcoal filters now.
Old Jul 1, 2010 | 01:48 PM
pdvng_mb's Avatar
C240 2003 4matic
I am from the cold tundra MN. Just got this benz for about a month.
Old Sep 1, 2010 | 11:16 PM
sirei808's Avatar
c200 Kompressor
I have a 2001 C200 W203 Kompressor.
I wanted to change the air cabin filter as well, but the manual does not mention anything about such. It talks about Charcoal Filter though.
Would anybody know if this model still have the Air Cabin Dust filter?
Thanks.
Old Sep 1, 2010 | 11:59 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
They all should have the dust filter.. above the battery.
Old Sep 2, 2010 | 12:10 AM
sirei808's Avatar
c200 Kompressor
yup Sir.. saw that. I am looking for the internal cabin filter as available on other models?
Old Sep 2, 2010 | 04:48 AM
samaritrey's Avatar
Super Moderator
THE C350
if you have it you will have the button on your climate control to turn it on and off. it is under the glove box. very fun to get to take off the black plastic thing and you will see the box with the two charcoal filters in it. I doubt a c200 has them if you don't have the digital climate control you don't have them.
Old Sep 2, 2010 | 06:48 AM
sirei808's Avatar
c200 Kompressor
will try to check over the weekend. Will advise and gtake some pics if I see one. thanks
Old Sep 2, 2010 | 08:17 AM
Glyn M Ruck's Avatar
Super Moderator
No 70 in diagram. Only fitted with Thermotronic and not Thermatic. In South Africa you could specify Thermotronic on a C200.
Old Sep 2, 2010 | 09:23 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
On my '07 C280 4Matic, a large piece of thermacoal was stuck in the location where #70 is shown (in the above picture Glyn posted). That thermacoal piece was put in at the factory. EPC says #70 is not applicable for my car. So, I only replaced the filter behind the battery.
Old Sep 2, 2010 | 09:24 AM
pcy's Avatar
pcy
pdvng_mb, why don't you return the part to the place where you bought it and get your money back. You will probably have to pay shipping. Call the place where you bought the filter set and get the Return Authorization.
Old Sep 2, 2010 | 11:55 AM
Super Moderator
By '07 most cars with Thermatic had that area totally blanked off so you could not retrofit. Earlier cars had blanking pieces inserted that would allow you to retrofit.
Old Sep 2, 2010 | 12:24 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Yep, my 07 is totally blanked off. I REALLY would love to retrofit, but I am not replacing the whole assembly to do so.
Old Sep 6, 2010 | 01:33 AM
vdubpower's Avatar
i drive them all, fast and hard
does the 05 c320 sport sedan have the under the glovebox filters, i was about to buy them assuming they did...not sure tho...
i dont have a digital ac control, but i assume it was top of the line for the yr, it being a 320
Old Sep 6, 2010 | 06:42 AM
Super Moderator
If it does not have Thermotronic then it won't have the charcoal filter but probably has the blanks inserted so you can retrofit. You need to stick your head under there & have a look.
Old Sep 6, 2010 | 02:28 PM
vdubpower's Avatar
whats thermotronics?
what doi i get out of it to retrofit, whats it do for me
weird thing is when i go on all the parts sites, it pulls up those filter parts
and doesnt when u go to stealership, in service b they are charging u for cabin filters, ?wtf, what if the car doesnt even have it
Old Sep 6, 2010 | 03:13 PM
samaritrey's Avatar
Super Moderator
THE C350
Yeah the took out the charcoal filters our to the w203 model line in like 03 or 04 from my understanding. You only have it if you have the digital ac controls. Mercedes i guess decided that the entry level car does not need a charcoal filter assembly. I would honestly just live with the charcoal filter that goes above the battery. i installed one in my car and now rarely use the secondary charcoal filters.
Old Sep 6, 2010 | 03:41 PM
Super Moderator
Thermotronic still came with Charcoal filters on newer units but then they used the correct trunking.
Old Sep 6, 2010 | 03:47 PM
samaritrey's Avatar
Super Moderator
THE C350
i was talking usa. glyn do they still offer charcoal filters in your neck of the woods in the w204?
Old Sep 6, 2010 | 03:48 PM
vdubpower's Avatar
what would entrail retrofitting, a whole new AC system?
sounds like it is just cheaper just to do the over the battery filter
Old Sep 6, 2010 | 03:49 PM
samaritrey's Avatar
Super Moderator
THE C350
The over the battery filter is like $20 instead of like $10 for the normal paper one.
