P0113 car wont start
Car started acting funny. Didn't want to accelarate. Now it simply won't idle. Pressing the gas makes it worse the car will die quicker. I cleaned the maf, nada response, left maf unplugged, nada.
The code refers P0113 - Intake Air Temperature Circuit High Input. That means that the MAF is telling the ECM that the temp is below -30. However, when I unplugged the MAF so that the car could run at the preset values, I got no improvement. I hear the injectors clicking, but I think there is no gas pressure since I can't hear the fuel pump prime when I put the key to on. Can I check for pressure by releasing the pressure on the line at the fuel rail? (of course my hearing is not so good) I have an extra maf I can try. But I think the code I am getting is a byproduct. Realize, this happened immediately after stopping to get gas. I only put Chevron Super in the car. Thoughts?. Can someone post up the WIS for replacing the fuel pump in a 2002 C230 Coupe? Thanks. Ed |
Ed, for a man of your talent replacing the fuel pump & sensor unit under the round cover drivers side rear seat is a walk in the park.
Maybe John or Karo can post the WIS method for you. https://mbworld.org/forums/attachmen...-tank-etc..gif |
Originally Posted by Glyn M Ruck
(Post 4227914)
Ed,
I posted the WIS in my thread from yesterday: https://mbworld.org/forums/c-class-w...ment-tank.html The fuel filter and pump are the same. |
John, SeaCoupe is asking for instructions for a 2002 C230 Coupe. The fuel filter in a 2002 model is mounted outside the fuel tank.
However, the instructions for replacing the fuel pump/sending unit are still applicable for 2002 model. |
Originally Posted by pcy
(Post 4228028)
2 Attachment(s)
Ed,
Attached is the WIS for the fuel pump specifically. Also found out us US guys don't need the fancy claw wrench. The sending units have a latching cover. Attached the WIS for that too. |
I have a 2007 c280 and went to replace the pump and the one I bought matches these instructions and Amazon says I got the compatible one, but upon opening everything up, it is different?
Doing some digging into the 2008 c300, it looks the same as the one i have. https://cimg3.ibsrv.net/gimg/www.mbw...7997cd680f.jpg |
