Licence plate light removal
Old Oct 3, 2010 | 03:44 PM
bruno2009's Avatar
W203 Saloon 320 CDI
Can anyone help?
I have purchased a pair of LED licence plate lights, not just the bulbs and need to remove the ones which are on the car at the moment' Has anyone actually manage to take these out?
Old Oct 3, 2010 | 06:51 PM
samaritrey's Avatar
Super Moderator
THE C350
search there is a diy posted a few weeks ago
Old Oct 3, 2010 | 07:48 PM
chkoo's Avatar
W211 E63, W205 C300
easy, take out trunk lid lining. once u get in there, u should be able to figure it out
Old Oct 3, 2010 | 09:11 PM
Xhale707's Avatar
C320 2002
Its very easy u have to remove a lot tho just to take out the llight socket
Old Oct 3, 2010 | 09:17 PM
Beepbeep's Avatar
2007 C230, S2000
If you have the US license plate, you have to remove that piece to have a better access from outside.
DYI should be just around the corner. Good luck.
Old Oct 3, 2010 | 10:06 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
lol i know you didnt search the forum because I posted a DIY on this like a week or 2 ago...wow man really?
Old Oct 4, 2010 | 02:28 AM
bruno2009's Avatar
W203 Saloon 320 CDI
I have done a search ' But can only find the post regarding adding the resistors and not anything regarding removing the entire light.
I have tried it removing the trunk lining and have pressed the clip in on the light but does the light come out through the trunk side or the outside?
Cheers
Old Oct 4, 2010 | 08:00 AM
ontmiss's Avatar
2007 C280 4matic Avantgarde
Cheers
It's kind of hard to find but here you go https://mbworld.org/forums/c-class-w...ixtures-2.html
Old Oct 4, 2010 | 11:11 AM
maverik259's Avatar
you have to remove the license plate fixture and they will pop out of the outside.
Old Oct 4, 2010 | 05:29 PM
bruno2009's Avatar
W203 Saloon 320 CDI
Many Thanks for all the replies' i found that post earlier today after much searching.
When i tried on Saturday i got as far as starting to remove the trim behind the licence plate, but wanted to double check that i was doing it the right way and will try again in the next couple of days weather permitting.
Old Oct 10, 2010 | 03:33 PM
bruno2009's Avatar
W203 Saloon 320 CDI
I have now sorted my lights out and many thanks for pointing me in the right direction.
Old Oct 10, 2010 | 09:48 PM
Beepbeep's Avatar
2007 C230, S2000
Glad to see you done it. This furom rocks!
Old Oct 31, 2010 | 09:33 PM
GotDaBenz's Avatar
'03 C320 Sedan, '04 SAAB 9-3 Cabrio
I recently replaced my license lights with hyper-white (regular, not LED) bulbs from Hoen. They are not cheap. One has gone out on me already after like 5 months. Anyone have this happen to them? Can the light fixture go bad or is it usually the bulb?
Old Nov 1, 2010 | 11:06 PM
maverik259's Avatar
bulb but you can simply check but putting the other working bulb into that housing...
Old Nov 2, 2010 | 04:24 PM
BF_JC230's Avatar
2005 w203 C230
Are people going through all of this trouble just to change the bulbs? I hope not...Maybe to replace the whole housing...But I would think that you do not need to remove the whole housing to "upgrade" the lights.
The lens holds the bulb, and is removable by the two stainless short through large course screws. It is PN A203 820 00 66...I know because I replaced both bulbs last night. You use a soft hook tool (Or I am sure a small flat blade screw driver / small hook) and pull off the lens once the screws are out. Once you are holding the lens, you are holding the bulbs, swap and go.
This is the second time I replaced the bulbs, after the first replacement, I added silicone lubricant to the landing area in the trunk lid, this helped removal last night, while adding a tighter water seal than the little gasket on the lens.
Hope this helps.
Old Nov 2, 2010 | 05:48 PM
maverik259's Avatar
yes we're replacing the entire fixtures not just the bulbs...i'd hope people could look and see the 2 screws on the lense and automaticlaly assume that you remove those to change the bulbs...
Old Nov 2, 2010 | 05:52 PM
GotDaBenz's Avatar
Put back original bulb, works fine(I guess I knew that was the obvious thing to do, don't know why I asked). Now Hoen needs to send me a replacement. Thanks, guys.
Old Nov 2, 2010 | 10:02 PM
BF_JC230's Avatar
2005 w203 C230
You never know...I have seen some rather basic questions...and some that make me shake my head...
Old Nov 3, 2010 | 08:30 PM
GotDaBenz's Avatar
Thankfully the license bulbs are easy to replace, as I have found to be generally true about the 203. The dome and trunk took a little more force than I would like but I got them out without breaking anything.
Old Nov 4, 2010 | 06:04 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
I took apart my trunk lid for the hell of hit it's about the simplicity.
