Cold crank
Old Nov 24, 2010 | 10:20 PM
mkim331's Avatar
05 C240
Cold crank
Outside temp. 0 degree celcius.
M112 60,000km. Brand new battery.
AVR testing performed today. Alternator and battery reads good charging voltage. P0131 came on once then cleared. Car drives fine as new. idleing is fine.
BUT CAR STUMBLES ON COLD CRANK FOR 30 SEC THEN STALLS. It barely cranks in about five more prompts. It cranks just fine when weather is nice. PleAse help.
Old Nov 24, 2010 | 10:41 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by mkim331
...Brand new battery.....
MB 100 ah battery?
...BUT CAR STUMBLES ON COLD CRANK FOR 30 SEC THEN STALLS. It barely cranks in about five more prompts. It cranks just fine when weather is nice....
What do you mean by "cranks"? Crankshaft turns over? Motor starts? By "stumbles" do you mean motor starts but misses and eventually stops?
Old Nov 24, 2010 | 10:53 PM
fookoo303's Avatar
2003 c240
just a heads up, you shouldn't start 2 threads on the same topic you might anger one of the moderators.
Old Nov 25, 2010 | 05:04 AM
Glyn M Ruck's Avatar
Super Moderator
P0131 = O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
Do you have the correct 100Ah battery?
As with the temp sensor I mentioned in the other thread. If your upstream O2 sensors are getting old and cycling too slowly the direct result is engine stumble because your fuel trim is wrong.
