EMERGENCY! AMAZING OPPORTUNITY, FREE COMMAND UNIT, PLEASE HELP.
Old Dec 11, 2010 | 10:55 AM
97W202's Avatar
2006 C230 6speed/14 C63
I NEED HELP ASAP!
I know there are many threads on all this but after searching I could only find bits and pieces, and right now thats not enough. I have a phenomenal chance at a FREE command unit.. with a catch..
a friend totaled his car, he has stock navi.
THE PROPOSAL:
Remove his head unit and replace it with mine, now I have navigation..
I was so excited I was up last night removing my center console already !!
This is where I need your help. When I go to remove this unit can anyone please advise everything I should have in my possesion before walking away from the donor? I want to make sure everything is present for a direct swap into my car.
Thanks guys!
Old Dec 11, 2010 | 11:23 AM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Hell yes.
To be honest, you need nothing. All you need is the unit. The DVD should still be inside, and if he has HK or CDC, hopefully you have it as well so the MOST ring will be active. I think the stock GPS antenna is routed throughout the car, so it's easier to just buy an aftermarket underdash antenna on ebay for about $10. Besides that, you plug it in, and smile from ear to ear. There's no vin coding or unlocking or anything else needed either. If you want the nav menu to show up on your center screen you'll need the SDS (I don't care for it so I never did it). It's gotta be the easiest direct swap known to man (shocking on a mercedes too).
Old Dec 11, 2010 | 11:49 AM
hcalvarez's Avatar
2005 C230 Kompressor
damn bro you got lucky! Free command what a find!
Old Dec 11, 2010 | 03:22 PM
97W202's Avatar
Originally Posted by Viper98912
Hell yes.
bro my face hurts from how long its been stretched from ear to ear, ever since I got the news Ive been jumping up and down hoping my manager decides to let me leave early so I can get to this.
Thanks for all the info man, I will pm you about the antenna, I could use your advice on which one to buy.
I KNOW!!!!!
Old Dec 11, 2010 | 05:49 PM
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
HERE is an article on the retrofit. It will give you a good idea of everything you need and such. I believe it even tells you where the factory antenna connections are, if it is present. It also talks about installing the AUX input connector at the same time.
