Dead Alternator.....
Old May 3, 2003 | 01:35 PM
Iceman's C230's Avatar
09' BMW M3 E90
Angry Dead Alternator.....
C230 has only 16K and the Alternator is shot.. It just happened after the Head gasket replacement. Had to get the car towed to the dealer. Here are the problems it had so far:
-Panaroma sunroof won't open.
-BAS/ABS warning.
-Check engine warning.
-No first gear.
-Key not working.
-Blown head gasket.
-SC replaced.
-Dead Alternator.
I wonder if it is time to sell
Old May 3, 2003 | 02:12 PM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
To every thing there is a season
No, it's time to keep it!
Look at all the new parts your car is getting. You'll be way ahead of those with "reliable" cars because your parts are a year or more newer than theirs are.
Your suggestion that now might be the time to sell is not uncommon. If you're suffering losses now, now is not the time to "lock those losses in" by giving up on the car. Persevere and you will be rewarded. Sell and you will be hammered on depreciation.
For example, my Peugeot 405 had quite a bit of early warranty work done - new head, new rings, new water pump housing, new seatbelt, new O2 sensor, new Bosch Motronic ECU....the engine work was done at under 30,000 km.
Now at nearly 300,000 km, the car is totally reliable, almost unbelievably so. All the bugs were worked out and for 14 years it's been good solid, stylish transportation. this car will easily surpass 400,000 km, maybe 500K.
I suggest that this could happen to your car too.
Old May 3, 2003 | 10:24 PM
Outland's Avatar
2002 C230 Coupe(M111)
Re: To every thing there is a season
Often times the installation is what makes the difference. Your engines are not made of unbreakabletanium. Each time you dig in to fix one thing, you have a chance of damaging something else. A tuner car is a different matter, but something you expect to have flawless reliablity as an everyday driver- I'd be getting a little nervous.
My old neighbor had a new engine put into his Celica GTS a few years ago after it developed serious engine oil consumption problems at less than 8K miles. That car was never the same again. He eventually dumped it because the number of problems. I told him at the time to demand a new car... 8000 miles is much too soon for a new motor.
Old May 3, 2003 | 11:39 PM
20FHK02's Avatar
2002 C230 Coupe
After my car's engine was torn apart due to leaking gasket, I felt a loss of power when it was fixed. Yes, the car will never be the same again after a major repair. But what can I do? I don't have the extra cash to get a new one...
Old May 4, 2003 | 01:18 AM
pokerFACE's Avatar
Not to sound (too) sarcastic, but if what you're saying is true, then Iceman should hope that everything else in his car eventually but **gradually** gets replaced under warranty... that means brakes, engine, tranny, suspension, emissions, body panels....
eventually he will have an entirely brand new car on his hands
quick! what's a 0.5*2002 + 0.05*2003 + 0.05*2004 + 0.4*2005???
Old May 4, 2003 | 01:49 AM
VoyagerDude's Avatar
2002 C230K, Silver, 6-speed, Evo, Roof, Leather, CD, Staggered C7 Wheels
Re: Dead Alternator.....
Sorry to hear about you alternator this time, Iceman.
I dunno, I think I'm a regular visitor at my dealer's service department: they routinely replace parts of my car. Minor things mostly (lately). Let's see, last week some plastic on the bottom of the seat, to get rid of squeaks there.
This monday I'm taking it in to have the roof rails replaced and the dr. window regulator replaced.
So it's always something
But overall I enjoy the car a lot, especially with the new 8.5" Evo wheels on the back (255mm tires) the handling has improved very noticably, esp. while cornering.
-BAS/ABS warning.
-No first gear.
-Key not working.
-Blown head gasket.
-SC replaced.
-Dead Alternator.
Old May 4, 2003 | 01:50 AM
Re: Re: To every thing there is a season
This is exactly what I was thinking abnout mine
Old May 4, 2003 | 02:10 AM
pokerFACE's Avatar
..has anyone noticed that by %, us Canadian W203 owners owned this thread? :o
Old May 4, 2003 | 02:40 AM
Woo hoo,
Let me quickly post another "filler" message
just to make sure we have more posts
Old May 4, 2003 | 02:42 AM
Here is my whine list
Code:
Date		Problem				Service Action							Fixed?
 5-May-2003	Roof squeakes when opening	Sun roof rails replacement
 5-May-2003	Window squeakes when opening	Driver side window regulator replacement
23-Apr-2003	Service broke key casing	Asked to come in and show them					N
23-Apr-2003	Tunnel Mode			Enabled for sun roof, free					Y
23-Apr-2003	Driver seat squeak		Replace plastic panel						Y
16-Apr-2003	Driver seat squeak		Order plastic panel						N
18-Mar-2003	Rattle engine noise		Install updated cam adjuster to correct rattle engine noise	Y
12-Mar-2003	Loss of power, hissing noise	Some air hose not re-attached properly by service		Y
11-Mar-2003	Rattle engine noise		Replace supercharger to correct rattle engine noise		N
 5-Mar-2003	Rattle engine noise		Ordered new supercharger					N
26-Feb-2003	Outside temp reading incorrect	Replace defective temp sensor					Y
26-Feb-2003	Rattle engine noise		Replaced defective timing chain tensioner (worn)		N
15-Jan-2003	Rattle engine noise		Service has no idea						N
 6-Nov-2002	Front suspension squeak		Install updated sway bar bushing				Y
 6-Nov-2002	Hatch squeaks 			Install some felt pads						Y
30-Jul-2002	Roof creaks			Cleaned								Y
11-Jun-2002	Driver seat squeak		Not fixed							N
11-Jun-2002	ABS/ASR/ESP/ETS failure		Overvoltage codes read. Replaced alternator			Y
 2-May-2002	ABS/ASR/ESP/ETS failure		Battery charged							N
		Hatch cover hinge broke off	Replace hatch cover						Y
No records between posession date and may 30, 2002
18-Jan-2002	Took posession :-)
Old May 4, 2003 | 11:41 AM
09' BMW M3 E90
Hi Voyager, i guess i should not complain after reading your list. It is just i don't have time in my hands these days to take this car in to service all the time. It is just frustrating that's all. I really like the car also but getting a little worried what is going to be next?
Glad to hear that you like your new wheels. Has the wider wheel package improved your handling?
Old May 4, 2003 | 03:46 PM
I hear you...
Maybe that is why I've just got my class 6 license and started looking at motorbikes
(Hoping to make the coupy jealous so it behaves )
Old May 4, 2003 | 05:10 PM
Outland's Avatar
[/code]
Quite a bit on the 'wine' list that appears to have been ordered by your waiter in error. A lot a misdiagnosis
Here's my list of problems @ 10K
Cracked "up" button steering wheel---> Replaced.
I look at a lot of these posts with dismay...my car has been rock solid- no squeeks, and an absolute joy to drive. My father in law owns a Lexus and a Boxster S - both have had numerous trips to the dealer since new- he's always surprised when we tell him "nope, no problems"
Old May 4, 2003 | 05:41 PM
Yes, you're right, good part of my return visits were related to misdiagnosis or a service guy screwing up something else while fixing a problem.
Regarding ordering wrong parts, sometimes I even think they do that intentionally, to get more warranty $$$ from MB.
