seatbelt
Old Jan 14, 2011 | 09:14 PM
nobli's Avatar
07 c230
seatbelt
hey guys. two of my backseat seatbelt buckles broke.( the black plastic) how would i go about taking them out ?
Old Jan 14, 2011 | 10:40 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
I believe it is bolted to the floor of the car, that's how it is in other "UN-NAMED" cars. I am pretty sure the buckle is replaceable..
Old Jan 14, 2011 | 10:45 PM
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
The receptacle part should bolt to the floor. Obvious once you get the seat out, just make sure you torque them back right if you replace them.
However, if you are talking about the black plastic that goes around the buckle part, I believe the only way to get that is to replace the entire belt/buckle assembly.
Old Jan 14, 2011 | 10:49 PM
Nike Turbo Shox
Correct. which was it again the OP said broke? are the seats belt in this car in any relation to the SRS airbags?
Old Jan 16, 2011 | 08:07 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
They're as one. SRS means Supplemental Restraint - airbags are supplement for the belts.
A problem with the front two buckles can cause the SRS light to illuminate. All outboard seats have pre-tensioners, and problems with those will also cause an SRS warning.
Old Jan 16, 2011 | 08:46 PM
Nike Turbo Shox
I see. thanks, if the seltbelt buckle malfuctions can that lead to the airbag prematurely deploying or cause it not to deploy in a car accident?
Old Jan 16, 2011 | 09:09 PM
LILBENZ230's Avatar
If the SRS light is on, your bags may not function in a crash.
