Passenger side mirror parking memory
Old May 10, 2003 | 03:56 PM
dragon's Avatar
CLK 350 convertible
I read in the owner's manual that we can turn the passenger side mirror to position in a way that it could assist us in parking but on the picture, it shows a memory button at the door side and it is only for those memory powered seat. Can my car with manual seat do the same as those with memory button?Any help will be appreciated.Dragon Baccarat System
Old May 10, 2003 | 04:14 PM
MB-BOB's Avatar
Admin Alumni
See Garage
I believe you get the tilt-down passenger mirror only with the power seat/memory package.
Old May 10, 2003 | 04:33 PM
dragon's Avatar
CLK 350 convertible
memory side mirror
Dragon Baccarat System Thanks Bob. Anyone can be positive that we cannot turn it on? Maybe I should call the service on Monday and check it out. This feature will certainly helps my wife,hehehe!!!
Old May 10, 2003 | 04:35 PM
dragon's Avatar
CLK 350 convertible
Neighbour
Hi Bob,I only notices that you are staying in the same town as my sister in law in Flower Mont,Tx. I think she is in Meadow Ridge.
Old May 10, 2003 | 07:19 PM
taylor192
Guest
Posts: n/a
Re: memory side mirror
I have asked one of the techies to try to turn it on his car that doesn't have power seats, waiting to see the results.
if you want to do it yourself, when in for service, ask them to hook up the DAS and try and find the setting and change it from NOT PRESENT to PRESENT and see if it works. Search the posts here for some DAS screen shots, its probably in the ICM menu sub-system.
Old May 10, 2003 | 07:53 PM
dragon's Avatar
CLK 350 convertible
Thanks Taylor, I will contact the service advicer on Monday and see if he can help.
Old May 10, 2003 | 09:42 PM
bajaiman's Avatar
01 C200 Kompressor, 02 C32 AMG
I wonder if we can turn the rain sensor on by setting the rain sensor to "PRESENT" from DAS ....
Old May 10, 2003 | 11:01 PM
R4ND0M_AX3's Avatar
C230
I think if you don't have the memory option then it won't work. The position that you want the mirror to go when in reverse is stored in memory. Part of the process of storing the position involves pushing the memory button that you won't have without the power/memory seats.
Old May 10, 2003 | 11:26 PM
dragon's Avatar
CLK 350 convertible
rain sensorx
Hi Bajaiman,
Rain sensor is an option, probably they won't turn it on if you did not have the option at the time of purchase. Dragon Baccarat System
Old May 10, 2003 | 11:28 PM
Lynn's Avatar
If your car doesn't have the rain sensor as an option, it isn't there. Setting it to "PRESENT" will do nothing.
Old May 10, 2003 | 11:30 PM
dragon's Avatar
CLK 350 convertible
Mirror
Hi R4NDOM,
After carefully read the owner's manual, I discover the small little asterick that denote that it can only turned on with power memory seat. Thank you to all in replying to my posting.Baccarat88
Old May 10, 2003 | 11:37 PM
MB-BOB's Avatar
Admin Alumni
See Garage
Re: Re: memory side mirror
This won't work... if it did, I would be heading for the dealer Monday morning to see if they can program the DAS computer to turn my C320 into a C32 AMG.
Old May 10, 2003 | 11:55 PM
peet's Avatar
09 C63
I dunno about this... someone with DAS please try it - after all, Mercedes would never put the 3 button key electronics in a 2 button plastic sleve... would they?
Seriously, give it a whirl. I miss this feature (bmw had it). The electronics are all there to do it - reverse sensor and motors what more would you need? Maybe a small memory chip.
Peet
Old May 11, 2003 | 11:38 AM
Matt230K's Avatar
2010 C300 4matic
I did try it, as you can see in the thread "What's the SOUND sound system?" It doesn't appear to work, although I am still wondering if it has anything to do with my manual transmission. Does the car still know when you are in reverse with the manual trans? I have been waiting for someone with a 6-speed and power seats to say if their mirror works.
Old May 11, 2003 | 12:32 PM
Blueice's Avatar
2002 C320
This won't work... if it did, I would be heading for the dealer Monday morning to see if they can program the DAS computer to turn my C320 into a C32 AMG. <- lol.. yeah dame I will do the same =P
Old May 12, 2003 | 07:43 AM
avlis's Avatar
2008 VW GTI
I have a 6spd and power seats. The mirror indeed tilts down in reverse.
Old May 12, 2003 | 08:09 AM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
As does mine.
Erik
Old May 12, 2003 | 08:28 AM
Matt230K's Avatar
2010 C300 4matic
Then I guess it won't work then, sorry taylor192.
Old May 12, 2003 | 10:11 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Your thought is correct.
The mirrors on a car with a memory driver seat comes with an adjustment motor that has 7 wires connected to it where as the non memory adjustment mirror motorts only have 3 wires connected to it...not a single change that the auto tiliting down feature can be activated through the standard 3 wires...it is controlled by the memory feature and it's additional 4 mirror motor wires!!!
greetingz,
Old May 12, 2003 | 12:27 PM
peet's Avatar
09 C63
So for the question on everyone's mind (well mine anyhow) ... if we refit the mirror housing with the 7 wire motor... assuming there's a plug for it, will the reverse mirror tilt thing work - without the extra seat memory electronics?
That would be an awesome hack mod!
Peet
Old May 12, 2003 | 05:19 PM
R4ND0M_AX3's Avatar
C230
Peet
The mirror won't know where to go. The electronics have the user defined reverse-down position stored in it.
Old May 13, 2003 | 01:42 AM
MBenzNL's Avatar
some slow@$$diesels
NO...otherwise it would already have been installed on my C250D a long time ago...
Those memory wires are not present in the non memory cars anyways...neither are the control units....
greetingz,
