Could these 0-100km/h stats be correct!!!
Audi A4 Quattro 2013
I just did some research on a w203 I may be test driving. The Sports model 2006.
0-100km/h in 9.7 secs That seams very slow.
Could this be true?
Could this be true?
2006 C230 6 speed
Not sure witch W203 your driving, i drive a 06 c230 2.5 V6 with 6 speed bone stock. I get to 60 in about 7.8 witch is slow. But the C230 is about looks not straight line speed.
Didnt drive it, just saw the stats
http://redbook.com.au/used-cars/details.aspx?R=83962
Super Moderator
Mercedes claims for the C200 are
9.4 secs MT, 9.7 secs Auto Wagon.
8.9 secs MT, 9.1 secs Auto Sedan.
C320 (Aftermarket)
well my friend has a C200K and we did a time on it. Its around 8.5 with 2 ppl in the car. But its a japanese spec W203, so i assume each region W203 has different power differences but not by much. By far i think the US spec W203 are slightly underpowered. But the W203s here in my country are all usually japanese or on gulf specs and almost every W203 are good in straight runs, but the only w203 we have here are C180K, C200K a few C230K and only 1 or 2 C240's. And all these vehicles perform good, even the C180K
Super Moderator
Super Moderator
C230 spec is equally the same. When the C230 nomenclature is used it means the 1800 M271 has a larger blower & more aggressive ECU tune.
In the USA they did not sell cars in C200 trim - only C230. In ROW the sedans were all C200 whereas the Coupe was available as a C230.
All these comments apply to M271 engined cars - not older M111 powered cars where nomenclature reflected capacity.
Super Moderator
C200 spec is the same worldwide.
C200K in gulf have 2.0 L engine and i own 2007 one from 0 - 60 in 8.2 s
All engines are differnet in gulf
Super Moderator
You are dreaming: Is yours a CGI?
2002-today M271
* 1.6 L (1597 cc) supercharged
* 1.8 L (1796 cc) supercharged/supercharged CGI
* 1.8 L (1796 cc) turbo
Give us your engine number & I will give you it's exact specs.
We are talking in W203 body here.
2002-today M271
No my car is kompressor and yes w203 body
I don't know if you are right but in the insurance paper that i have for my car is written that the engine dispmlacment is 2000
This is the engine number
27194030858161
Super Moderator
Your engine is a 1796cc with Kompressor. Output 120 kW at 5500 RPM. Torque 240 Nm between 3000 & 4000 RPM. Acceleration 0 - 100 km/h (S mode - Auto) 9.1 secs.
8.2 is my time
Even with 9.1 it's still faster than those stats mentioned above that's means engine powers differs from one country to other
Super Moderator
The engine power does not vary by country. I have explained the different states of tune available. The slower times mentioned above are for the station wagon because it is heavier. A C200K is a C200K worldwide. Even a manual C200K will only do 8.2 down a mine shaft.
Super Moderator
These are the M271 engines as fitted to the W203
Now we have in addition fitted to the W204 & other models:
* 1.6 L (1597 cc) supercharged - fitted to Blue Efficiency models
& the * 1.8 L (1796 cc) turbo - fitted to some new 2012 models
W203 - M271
W203 - M271
C320 (Aftermarket)
I think so too because i was told MB in every region had different power outputs on the models produced. Some models were not available to the US as well. But i am only familiar with the gulf spec and japanese spec W203 and when compared to the US spec it was a bit different but not by much.
C320 (Aftermarket)
