Tocking sound in car
Old Apr 20, 2011 | 08:33 AM
anonymousmoose's Avatar
Audi A4 Quattro 2013
Question Tocking sound in car
After driving the car today, when I pulled into the carport and turned the radio off, I can now hear a tocking sound from within the car.
I'm sure its coming from the engine and it is noticeable when idling. When I accelerate in neutral, it tocks faster and then goes away.
The tocking is as if thing is tapping in the car. When I open the engine bay to hear it, I can hear it slightly as the noise is muffles by the engine noise.
Also, this is when the climate control is off. When its on, I cant hear it as much, but once again, probably because its muffled by the fan noise.
Old Apr 20, 2011 | 08:54 AM
Glyn M Ruck's Avatar
Super Moderator
Search purge valve.
Old Apr 20, 2011 | 08:57 AM
Originally Posted by Glyn M Ruck
Search purge valve.
Thanks, is this a wear and tear part (need to see if its a warranty claim) and is it inexpensive?
Old Apr 20, 2011 | 10:18 AM
Super Moderator
Cheap - just get noisy over time. Will not lead to a failure.
Old Apr 20, 2011 | 11:08 AM
Click below to listen. Turn your speakers right up and you'll hear the tock.
Purge Valve?
http://members.e-wire.net.au/~carolineyw/MercTock.wav
Old Apr 20, 2011 | 11:15 AM
mskembo's Avatar
2010 Mercedes-Benz E350
Granted I'm listening on MacBook speakers, but it sounded healthy to me! The purge valve is on the... well, I have no idea where it is in a left hand drive car! In a right hand drive car it's on the driver's side right next to the ABS system.
Old Apr 20, 2011 | 11:24 AM
Search purge valve.
Its the tocking but you gotta turn the sound right up. Maybe it is healthy but lauder then before. It also varies, sometimes its quieter then other times.
I'm not worried, its just a bit annoying thats all. I'll go the the specialist I'm getting the AUX cable installed from and ask their opinion. If they know what it is without needing to keep the car, I'll then goto the dealer I bought it from (not an MB dealer) and ask if it can be sorted under warranty. If not, I'll ask the specialist.
Old Apr 20, 2011 | 03:51 PM
samaritrey's Avatar
Super Moderator
THE C350
Could it be your cooling fan? you can unplug it for a minute to test
Old Apr 20, 2011 | 04:20 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Auxillary drive belt ? . With the engine stopped ,moisten the inside of the belt slightly with water & see if the noise changes,.
Old Apr 20, 2011 | 09:36 PM
Thanks, I'll have to find out how to do this but google is my friend :-)
Old Apr 20, 2011 | 09:37 PM
will try. Car booked in with dealer on Wednesday next week.
Old Apr 20, 2011 | 09:39 PM
I got a screwdriver out yesterday and held it onto the Purge Valve and held my ear next to it. The purge valve didnt seam to make noise but when put the screwdriver onto the hose connecting to the purge valve, it was pulsating similar to the ticking.
I got my wife to accelerate and the hose pusating increased, similar to the ticking in the car.
I've got it booked in on Wednesday with the dealer I bought it from. I'm not too concerned but it sure is annoying. Its very noticeable when radio & climate control is off.
Old Apr 21, 2011 | 01:33 AM
samaritrey's Avatar
Super Moderator
THE C350
sorry was in a rush if you look down where the fan is there is a connector on the right side at the bottom of the fan casing it is a pretty big connector with good size wiring going to it. It has some connector that you have to wiggle out. just don't forget to plug it back in and make sure it works lol
Old Apr 21, 2011 | 02:53 AM
Went to a specialist today about an AUX lead I odered and he took a quick look. He said if it's the Purge Valve, it's not an uncommon sound and suggests not to bother with it as even a replacement may start making the noise. He was a bit concerned that it could be something with the belt. It's going to be looked at by the dealer on Wednesday next week.
He said the engine looked good and there is no need for any immediate concern, but to get it diagnosed under warranty will be a good idea.
I will give the fan troubleshooting a try.
