Location of the reversing light switch C230 Sport Coupe - 6spd
Old 04-26-2011, 09:19 PM
colin42's Avatar
2002 C230 Coupe - Manual
My reversing lights don't work in my 2002 C230 Sport Coupe. I've check both bulbs but they are fine so i believe the reversing light switch is the cause of the issue - the problem is i can't find it - In every other car (that I've looked for it) it is accessed from within the car by removing the trim around the gear stick, however in my car there are no switches near the gear leaver and only the linkage going the the gear box. If anyone has a photo or diagram from the repair manual that would be great.
Old 04-27-2011, 12:01 AM
Jp's_C230k_W203's Avatar
2005 c230 kompressor
Have you checked the harness that goes into the bulb housing to see if there is any power going to the bulb socket??
Old 04-27-2011, 10:50 AM
6speedclk's Avatar
CLK500
It on the trans.
Old 04-27-2011, 02:18 PM
Question
My bad I read it wrong.
Old 04-27-2011, 02:23 PM
Old 04-27-2011, 08:13 PM
colin42's Avatar
Originally Posted by 6speedclk
It on the trans.
Do you have a photo or diagram?
Can you see it from under the vehicle?
Old 07-25-2017, 12:58 AM
SweeneyD24's Avatar
Mercedes-Benz C200K
Did you fix it?
I'm having the same issue on my dad's 2004 W203. Bulbs are fine but no reverse light.
Old 07-25-2017, 09:40 AM
6speedclk's Avatar
CLK500
Better late then never!
Quick Reply: Location of the reversing light switch C230 Sport Coupe - 6spd
