Is this the GPS ant. I need?
Old May 23, 2003 | 01:40 PM
spongebob's Avatar
I bought a Comand (463) 2.0, I'm trying to fit it into my c320.
I was wondering if this is the GPS ant. I will need? if not, can any1 point me a place I can order?
thanks,
Old May 23, 2003 | 03:17 PM
Enze6997's Avatar
E350 Coupe (2010)
Looks like it to me
Old May 26, 2003 | 12:09 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Yes, that is the one...but don't get misleaded by the MB partnumber on that sticker...the OEM MB GPS antenna comes with a wicklick connectors...not with that HRS connector (the antenna on the picture is modified).
greetingz,
Old May 26, 2003 | 04:39 AM
cobraeins's Avatar
203.264
@MBenzNL
Hi,
I think this one "A209 820 0875" from the 209 Cabrio could be the right one...
Old May 28, 2003 | 02:14 AM
SUNILP's Avatar
2015 E250D
Steve is correct
The antenna has been modified with a HRS connector. Nonetheless, it should be fine. You can get an aftermarket antenna also. I have the site somewhere. Email me if needed. Otherwise, steve can get you one also that will work.
Old May 28, 2003 | 02:04 PM
MBenzNL's Avatar
some slow@$$diesels
The 209 GPS antenna is the same WISI antenna as the 203 one...with the only difference that the cable is shorter...the 230 GPS antenna is similar as well but comes with even a shorter cable then the 203 one does...all 3 antenas come with wicklick connectors...not with HRS connectors.
greetingz,
