Oil level check
how do you get the oil level check through the MFD
ive followed the instructions of putting key to on position and letting it figure it out but it just sits there and doesnt get the level |
tried what it says on page 236, still didnt show..ill try again
When I do it, here's how it usually goes.
Sometimes, when the engine isn't warm enough or when the moon is in the wrong phase, it will say "OBSERVE WAITING PERIOD" or even more abstractly "MEASURING NOT POSSIBLE." When I get that last message I usually say "Would be if you gave me a flipping dipstick." What is yours displaying? |
I always start in position 1, cycle to the oil level menu, and then click over to position 2.
All you gotta do for your facelift model is use the up arrow keys on the wheel until you see the oil can, but you must start out at the odometer screen. Make sure the engine has been off for 5 minutes at minimum and that the car is level, the ignition turned on and it will say "Measurement in progress" - then give you an "Oil Level OK" message. For an accurate quantity you'll need to search the forum for how to engage dyno mode and you can see exactly how many litres of oil are in the sump.
