HELP! Should I buy these!!!!
Old Aug 19, 2011 | 12:38 PM
mt8667's Avatar
2005 C230K Granite Gray
Anyone have any knowledge on these, I've read the other forums, just wanted to get some last minute input.... Thanks!!
http://cgi.ebay.com/ebaymotors/DEPO-...item23135a4a7f
Old Aug 19, 2011 | 01:00 PM
phister's Avatar
06 C230 SS 6spd
if you're wanting to spend that much on them they're ok. You can just buy regular Depo projectors for like 165-200 and buy some HID for 35 from our sponsor here and install them yourself. you'll save 100 or more. but if you dont want to do that they'll be fine.
Old Aug 19, 2011 | 03:38 PM
awacsdavid's Avatar
CLS500 & C230 Kompressor
+100000000000
Old Aug 19, 2011 | 03:59 PM
smacone's Avatar
Mercedes W203 C220 Sports Coupe
Since we're talking about Depo headlights, are there any left for the Coupe ?
Old Aug 19, 2011 | 04:55 PM
Norwichdelta06's Avatar
2007 c230
I wouldnt the hot spots on that thing is horrible.... but you can do an easy retro with e55 projectors
Old Aug 19, 2011 | 06:48 PM
MBfinatic's Avatar
e36 318i, 2004 sti
They will work fine as long as you get your car programmed otherwise your bound to have flikcering, and heat issues etc...
Old Aug 19, 2011 | 11:34 PM
C280AF's Avatar
"The Beast" C280 4MATIC, 2007 AUDI A4 S-Line Black on Black
I bought these same exact ones, threw in some HID's (didnt like the color output selections they had), plugged in some error code diffusers from ddm and good to go. Not a bad upgrade! No problems the last 4 months with em.
Old Aug 20, 2011 | 11:46 AM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
I'm considering upgrading my headlights and I am clueless on this subject. I mean I know some of the terms (which is already dangerous!) but I'm not sure how they all fit together. Are you suggesting here that you get Depo projectors without bulbs and get the bulbs elsewhere? Where would you get the projectors? I did a search on Ebay for "depo projector w203" and didn't see anything less than $290. Here is the cheapest: http://cgi.ebay.com/ebaymotors/01-06...item4840a821f8
It said this in the ad:
Low beam bulb: H7 halogen (not included)
High beam bulb: H7 halogen (not included)
HID Compatibility: YES - aftermarket H7 Kit (modification required)
What sort of modifications are they talking about?
Enlighten me, please.
Old Aug 20, 2011 | 12:27 PM
giannidy's Avatar
2001 C320
^^^ I dont know about any modification. When I installed my DEPOs with a friend of mine all we did was install the HIDs straight up plug and play... No modification. The only problem I had with it was forgetting to switch the xenon=present setting
Old Aug 20, 2011 | 01:44 PM
C280AF's Avatar
There is no modification needed with these..
A quick DIY instruction...
- purchase these lights
- purchase HID lights 2 sets if your doing Highs and Lows (make sure you choose the color output u want.. i.e white, blueish etc your preference)
- purchase a set of error code diffusers from ddm tuning
Once you have all that...
- loosen front bumper screws (there is a diy for that on here)
- remove OEM headlight unit
- install depo unit using exsiting hardware from OEM unit
- insert HID bulbs
- install error code diffusers
- test lights
- tighten front bumper screws
Done!
Some cars require xenon present changed, some dont, its hit or miss.
