BAS - ABS Problems
Old Jun 3, 2003 | 11:04 PM
webhost's Avatar
2003 C230 Coupe
BAS - ABS Problems
Hi, I am new to the forum, I have tried to search this topic but had no luck.
I have had my 2003 C230K since February, over the last few days I have been getting some error messeges from the display that say:
BAS - Visit Shop Soon
and
ABS - Visit Shop Soon
Has this happened to anyone? is there anything I should know before dropping it off at the dealer? I have made an appointment for it to be looked at and was wondering if anyone here has been having similar problems?
Thanks in advance, and thanks for the forum.
Old Jun 4, 2003 | 12:17 AM
Matt230K's Avatar
2010 C300 4matic
A common problem on C-classes has been BAS/ESP errors, but your problem sounds different. Since you have BAS and ABS, it definitely sounds brake related. Hopefully the dealer will be able to find the problem.
Is the code always there, or does it go away? If it's always there, then hopefully it will show up in the DAS computer at the dealer and they will know what to fix.
Old Jun 4, 2003 | 12:18 AM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
Hmmm
That seems as though what you're describing is a variation on the ESP/BAS error that's happened to many C owners.
If it's similar, a new wiring harness unit update kit may cure the problem, which is the development of high resistance in some sensor wiring connectors. Ask your dealer about it.
Matt230K's Avatar
2010 C300 4matic
Oh, and welcome to the forum!
Old Jun 4, 2003 | 08:14 AM
tsberkey's Avatar
1988 560SL (Sold)
Re: BAS - ABS Problems
and
Webhost--
I just picked up mine one month ago and I have the same problem. It was supposed to be in for service last Wednesday but I was too ill to take it in! As soon as I find out the problem, I will post my results. Please do the same if you find out anything beforehand.
Tim
Old Jun 4, 2003 | 05:43 PM
BenzC240's Avatar
C240 02
Yeah I had that also when i first bought the car 2 years ago. Went to the dealer turned the car off and then on and it went away. It never came back. It was checked out and no error codes came up. It could be a sensor assuming u dont have another issue. But with benz it could be a number of issues. Good luck
Old Jun 5, 2003 | 04:08 PM
webhost's Avatar
2003 C230 Coupe
Re: Re: BAS - ABS Problems
Originally posted by tsberkey
Webhost--
Tim
Hi Tim,
They looked at it today, they ordered the parts needed to fix, it is a pretty minor issue. I was wrong about the error, it's a BAS/ESP error not a BAS/ABS error. I will keep you posted, but after searching for the right thread, I don't want to beat this dead dog to death.
BENZC240:
I think your attitude is leaving something to be desired.
Let me give you some tried tested and true advice:
The sooner you stop crying and bellyaching the sooner things will turn around for you. Attitude like motivation will help you along through life. Just my 2 cents after reading a few of your other posts here.
Old Jun 5, 2003 | 09:20 PM
BenzC240's Avatar
C240 02
thanks web but no attitude will ever change the quality of my car
Old Jun 5, 2003 | 09:32 PM
tsberkey's Avatar
1988 560SL (Sold)
Re: Re: Re: BAS - ABS Problems
Hi Tim,
I really don't remember which one mine was since it's been about a week since I've had it, but it sounds just like this! Thanks for letting me know so quickly.
Tim
Old Jun 5, 2003 | 10:40 PM
Matt230K's Avatar
2010 C300 4matic
LOL!! Even the newbies can see what's going on.
Old Jun 6, 2003 | 12:38 PM
tsberkey's Avatar
1988 560SL (Sold)
webhost
I spoke too soon. As soon as I went out for lunch today, guess what error message showed up? And yes, it was the same as yours.
Old Dec 16, 2005 | 10:07 AM
SuperQ's Avatar
06 C230
i am getting this error too!
Old Dec 16, 2005 | 10:17 AM
jrct9454's Avatar
'14 GLK250 Diesel
As noted above, the fix for this is known. Just get it to a dealer and ask them to get on with the service bulletin on this problem. It involves a new wiring harness and new gold connectors. Parts may need to be ordered, depending on the dealer and how many of these they've done.
Ours was throwing intermittent messages for most of the three years we've owned it, but always went away after an engine shutdown and restart. Usually months would pass between messages, but just before a long trip this year, it happened twice within a month - so I had the fix applied, and no problems since.
