MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   C-Class (W203) (https://mbworld.org/forums/c-class-w203-3/)
-   -   Car won't start. Pointers? (https://mbworld.org/forums/c-class-w203/420393-car-wont-start-pointers.html)
euromedic Oct 24, 2011 07:00 PM
Came back from trip, needed to run errand. Turn over key, everything powers up normally. Turn key to start car, nothing happens. Any ideas? Thanks.
Glyn M Ruck Oct 24, 2011 07:31 PM
If the car does not crank check fuse 52 & replace 15A with 20A
If it cranks check fuel pressure is min 3.8 bar. Be suspicious of CPS.
EDIT: you need fuses 31, 52 & 57 to enable start.
MB///HRV Oct 24, 2011 07:35 PM
Check starter
Glyn M Ruck Oct 24, 2011 07:50 PM
99.9% of the time it is underated fuse 52 & not the starter motor.
tc1728 Oct 24, 2011 09:03 PM
if it does not click when you turn the key, check the starter, if it clicks and does not turn over, check your fuel pump. TC
MB///HRV Oct 24, 2011 09:23 PM
Understood. My fuses were fine and it was the starter for me. About 140-50k miles at the time. Always check the easiest cheapest things first.
TruTaing Oct 25, 2011 01:26 AM
If your lights turn on but you car doesnt event attempt to crank. Doesnt this imply its your battery?
When my battery died, I called MB-Road side and they were able to tell me it was my battery by just having me try to turn on my headlights. They also came out and jumped me for free and I was on my way to getting a new battery.
Glyn M Ruck Oct 25, 2011 09:26 AM
If it is the battery. Your lights will generally come on but dim substantially when you attempt to crank.
euromedic Oct 25, 2011 10:11 AM
Well...went to check fuses in all 3 locations, and found significant amount of water in motor compartment panel. All fuses good, but no lights and no crank. Battery appears to have plenty of juice. This could become expensive :-(
Glyn M Ruck Oct 25, 2011 10:26 AM
Water in the front SAM? - not good. Next to check is the starter relay & finally the starter motor
Glyn M Ruck Oct 25, 2011 10:46 AM
For info:
https://mbworld.org/forums/c-class-w...t-process.html
euromedic Oct 25, 2011 11:03 AM
Thanks all for pointers so far. Gonna have battery tested just to verify its good.
Glyn M Ruck Oct 25, 2011 11:17 AM
Yep - get it properly load tested. If it were battery & would expect you to hear the starter bendix solenoid kick in but not crank.
© 2026 MH Sub I, LLC dba Internet Brands
