w204 shift knob
Old Dec 28, 2011 | 03:27 PM
drtyjrzy's Avatar
05 C230K Sport
w204 shift knob
does anyone know if a 204 auto shift knob will fit on a manual 203? found a sweet shift knob on German eBay.
Old Dec 28, 2011 | 03:31 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
I'd just play with one at your local Joisey showroom and see if you can tell that it's the same convoluted mechanism. Hopefully, they're not, and it's a simpler affair, but knowing MB, I'd be surprised if they improved it.
Have you checked the W204 forum? I'm sure that someone there has outlined the procedure for removing and reinstalling one.
Old Dec 28, 2011 | 03:40 PM
drtyjrzy's Avatar
05 C230K Sport
I did check the 204 forum and found some threads but not the info I was looking for. or at least not enough to bet 160 dollars on. I was thinking maybe someone owned both and knew if was the same shifter stem or maybe someone tried a swap already.
Old Dec 28, 2011 | 06:23 PM
drtyjrzy's Avatar
05 C230K Sport
ok new plan, I found a w212 manual shift knob from a different seller in Germany. I have found a lot of aftermarket knobs that say they will fit w203 and w212 so I think it should fit without a problem.
http://item.mobileweb.ebay.com/viewi...id=54978752379
here's a link in case anyone else is interested. I can't be the only one who doesn't like the ones at formymercedes.
