lowering springs...
Old Jan 18, 2012 | 12:57 PM
Phillyc230's Avatar
2007 Mercedes C230 sport 6spd
lowering springs...
I found these lowering springs for a w203 but it says its for 03-05 would it still fit my 07 c230 sport?
Old Jan 18, 2012 | 12:58 PM
Phillyc230's Avatar
They are made by tein btw.
Old Jan 18, 2012 | 01:05 PM
Phillyc230's Avatar
Would it make a difference in the drop since the 230 is already low from factory you think the teins would make a 2007 c230 low hopefully you guys kno what i mean by this
Old Jan 18, 2012 | 01:51 PM
glocati's Avatar
2016 GLE 350
They will fit. W203 applications fit the full run of production. 4-Matic and wagons excluded.
The advertised drop is typically based on non-sport cars, so you are right in that you will not get the advertised drop on your already lower sport suspension. I beleive the sport susp. is .5 inch lower than non sport, so subtract that from advertised drop and that is what you get. Proabably only half an inch versus an inch for example.
Old Jan 18, 2012 | 04:38 PM
Phillyc230's Avatar
ill jut sav for coils thanks
Old Jan 18, 2012 | 04:55 PM
iJimpanzee's Avatar
2009 SLK 55 AMG
4matics use different springs don't they?
iirc Vogtland springs?
Or it's a different suspension from non-4matics?
Old Jan 18, 2012 | 10:28 PM
kirax2's Avatar
I drive a Toyota Hybrid...
Old Jan 19, 2012 | 12:41 AM
glocati's Avatar
2016 GLE 350
yea, pretty sure vogtland is the only manufacturer with specific 4-matic springs. Front springs are different due to different front end set-up due to the differential and half shafts up front.
