MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   C-Class (W203) (https://mbworld.org/forums/c-class-w203-3/)
-   -   Trunk won't open...Please help (https://mbworld.org/forums/c-class-w203/465330-trunk-wont-open-please-help.html)
Bill B C320 Sep 30, 2012 03:29 PM
Hi guys,
I'm new here and have a 2001 C320. Today I went to the local tennis courts, and was leaving when the electronic key wouldn't open the trunk. When I got there an hour earlier, it was working fine. I could hear the motor(?) trying to open it, but it wouldn't release. :confused: I tried with the metal key, but that didn't do it either... I have searched through previous threads, but haven't seen any with the same issue.
Thanks,
Bill
phister Sep 30, 2012 06:45 PM
have you tried the trunk button on the driver door? or just hit the unlock button on the car and just pull on the release handle on the trunk really hard.
Bill B C320 Sep 30, 2012 09:28 PM
Thanks, I tried both ways, but neither worked. I eventually got it to open with the metal key, but had to turn it hard until I heard a click. Any idea what the problem is?
Akhafeez Sep 30, 2012 11:09 PM
its clear of any obstructions i'm assuming? check the actual lock mechanism on the trunk and the bumper. Try using the key when you have it open
Bill B C320 Oct 1, 2012 12:22 AM
Thanks, no obstructions. Have to look more closely at the lock mechanism tomorrow. Am already going to mechanic this week, so will probably have them check it out.
jtalbert Oct 1, 2012 07:56 AM
When you press the truck button on the key, do you hear a click where its trying to activate the trunk?
tommy Oct 1, 2012 08:35 AM
Try resetting the emergency release inside the trunk. That's another possibility.
Bill B C320 Oct 1, 2012 05:06 PM
Thanks, yes, I tried that and it sounded like it was trying to release it, but nothing happened...
Bill B C320 Oct 1, 2012 05:07 PM
I'll give that a try, thanks.
Darkman Oct 5, 2012 03:29 PM
I had the same problem before. Use the metal key to open the trunk: insert the key into the trunk keyhole, turn it counter clockwise and pull on the trunk handle to open the trunk. After you get the trunk open, spray lithium grease on the trunk latch. I haven't had any problems since.
Bill B C320 Oct 5, 2012 07:24 PM
Thanks, will definitely give it a try. Took it to my mechanic for wheel balance, and he seems to think it's an actuator.
© 2026 MH Sub I, LLC dba Internet Brands
