Car will not start. Please help 03 C240
Old Oct 5, 2012 | 10:32 PM
cmh1991's Avatar
'03 C240 and '05 C230
This afternoon I went to go run some errands. The car started up fine and then I drove it less than a couple of miles. When came back to the car, I tried starting it and the car just turns over and won't start. I tried to start it 3 times and then an hour later, I tried it again another 2 times but it still won't start.
Does anyone know what the issue could be? I don't think it's a bad battery since the car turns over.
Old Oct 5, 2012 | 10:57 PM
contact148's Avatar
2003 c240 4matic wagon
could be crank position sensor
did check engine light come on??
if you have a scanner check for codes
Old Oct 6, 2012 | 02:08 AM
benzmodz's Avatar
W203 slightly modified
When this happens I put in a new fuel filter and also a CPS.
Old Oct 7, 2012 | 03:47 PM
cmh1991's Avatar
Unfortunately I don't have a code reader with me at school but I looked at some different things that might have gone wrong and determined it was the fuel pump that went out (99% sure). I removed the rear seats in the back and when I tried to start the car, the fuel pump wasn't making any kind of sound.
Its got a lot of miles on it so its not unusual for it to go bad. Will be ordering a new fuel pump and see how it starts.
After what mileage should you supposed to replace the fuel filter. I don't think mine has ever been changed out, unless the dealer did while it was under warranty.
Old Oct 7, 2012 | 03:48 PM
cmh1991's Avatar
what does the CPS do? Also, is it easy to replace?
Old Oct 7, 2012 | 04:46 PM
Glyn M Ruck's Avatar
Super Moderator
The CPS tells the ECU when the engine is at TDC so it knows when to fire the plugs.
Fuel pump &/or filter are other likely causes. Check fuel pressure at the Schrader valve on the fuel rail that connects the injectors. s/b > 3.7 bars or 55psi while cranking.
All ~ I'm travelling & will be home evening of 9th. Will answer outstanding PM's then.
