pics of my car lowered with SACHS with SuperSprint exhaust
Old Aug 13, 2003 | 11:42 PM
Keyser_Soze's Avatar
C230 Komp Sedan - 2003
Thanks breastroker. I'm glad I got you with the M271, you seem to be the most motivated owner with lots of good technical knowlege. by the way i'm a mechanical engineer! i might be able to design the IC!! maybe we can start a business!
Old Aug 14, 2003 | 12:05 AM
breastroker's Avatar
2003 C230 K , 2001 ML320
Keyser_Soze,
Check my posts here and at http://www.csportcoupe.com/forums/fo...p?s=&forumid=1
The APS design is a form to start with. We need to research pressure drop across different cores that fit our space constraints.
Since the majority of cooling is in the first third of the IC length is not as important as height and depth.
I have worked in the oil, gas and power indistries for 30 years. Been around instruments at a power plant for years, delta P etc are common challenges. It can be done better than the RaceTec and TennTech ICs.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
