Poorly maintained C230K
Old Apr 23, 2013 | 12:08 PM
Lgraz5's Avatar
2003 C230K & 2007 C230
Quick update on my poorly maintained 2003 C230K with the 230K miles, original plugs, battery, worn-out suspension, etc.: on a recent trip I got 39MPG!
Old Apr 23, 2013 | 08:37 PM
kirax2's Avatar
I drive a Toyota Hybrid...
Old Apr 23, 2013 | 09:42 PM
jetta02awp's Avatar
2002 C230 Coupe Kompressor 6mt
I believe none of that except original plugs. Unless you had an 80 mph tail wind with the engine idling and tranny in neutral.
Old Apr 23, 2013 | 09:52 PM
Moviela's Avatar
Sounds like your instrumention or computation is off. I recall during the Apollo program my father-in-law was called in the middle of the night by mission control seeking advice as telemetry reported 3700 Kilos of fecal material in the holding tank. He advised the astronauts should don their space suits and hold on outside because if the data is correct, the capsule is full of Sh*t.
(It was only 3.400 Kilos)
Old Apr 23, 2013 | 10:50 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
Interesting story, Movie. Even more interesting is the factor that the factor the actual value was off from the reported. You might expect a multiple of 10 or 2.2 but not .92!
Incidentally, I agree with you about the mileage. My car has never reported much over 32mpg (which was likely optimistic). 39mpg probably requires a down-hill trip with a tail wind and never using your brakes.
Old Apr 24, 2013 | 05:36 AM
Alexbenz's Avatar
Sean's Sister--
Add a faulty gauge cluster to the list...no way that's correct.
Old Apr 27, 2013 | 04:49 PM
Lgraz5's Avatar
What a bunch of jerks! Of course it is true. Filled tank on highway, cruised at 65 MPH, all highway. See picture taken en route.
Old Apr 27, 2013 | 05:18 PM
ncmudbug's Avatar
Try this:
  1. Fill up the tank
  2. Note the mileage
  3. Drive
  4. Fill up the tank again
  5. Note the amount of gas needed to refill the tank
  6. Note the mileage
  7. Compute mpg
The computer does not give a reliable mpg number.
Old Apr 29, 2013 | 02:32 PM
kirax2's Avatar
try this, fill your car up with only 10gal of gas and see if you can get 400 miles out of it
Old Apr 29, 2013 | 03:09 PM
Alexbenz's Avatar
Sean's Sister--
Originally Posted by ncmudbug
Try this:
  1. Fill up the tank
  2. Note the mileage
  3. Drive
  6. Note the mileage
  7. Compute mpg
this, i see so many people posting up ridiculous numbers but this is the best accurate way
Old Apr 29, 2013 | 11:15 PM
TexFinn's Avatar
10 Tahoe LT, 07 Silverado Z71, 99 BMW R1100RT
Cool story, bro!
