Uneven acceleration issues?
Old Sep 30, 2013 | 04:04 AM
Koru_Kinshi's Avatar
2018 E63S AMG, 2003 SLK 230 Sport, 2004 SL 600, 2006 SLK 55 AMG, 1998 E320 Wagon
I seem to be having a bit of an issue with acceleration on my C230 coupe. 2002.
If I accelerate from a stop, it always seems that from stop to say around 2100RPM, acceleration is slow, but after that, it picks up pretty quickly. I recently did a throttle reset which seemed to help things a little bit, but now it's back to it again.
Any suggestions on what it might be?
Old Sep 30, 2013 | 09:16 PM
jkowtko's Avatar
2005 c230SS
You're not starting out in second gear, are you? Can you count the gear changes as you accelerate from a stop?
How many miles on the car, and how long since the last full tranny flush?
Old Sep 30, 2013 | 09:49 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
The supercharger in M111 is supposed to "kick in" at around 2k RPM from my understanding.
Hence the faster acceleration.
Old Sep 30, 2013 | 11:15 PM
I'm starting in 1st. Manual transmission.
Old Oct 1, 2013 | 07:38 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
try conductor plate in the tranny, thats how mine started then it wnet in to limp mode. i know its drastic but check it.
Old Oct 22, 2013 | 08:44 PM
Alright, so after using my Torque app on my car, I found that on WOT, anytime I'm below 2000-2200 rpm, throttle will only go to 35-40% max even with my foot to the floor, but as soon as the engine goes above that mark, it kicks to 100% throttle. I tried the throttle reset trick, and that only helps a little, then it goes back a few days after.
Any ideas what would cause that?
