Rear Suspension Replacement and Alignments
Old 11-26-2013, 08:45 PM
97C230's Avatar
97C230
I am in the process of replacing the front control arms and tie rod ends in my 2006 C350 4matic. With 80k on the car, I'd rather replace rear components at the same time rather than getting two alignments (assuming I have to replace rear components soon). Can anyone confirm what parts adjust the camber and toe on the rear end (if any)? I see that the wiki states there is a rear toe adjustment, but I didn't see a camber adjustment.
Id prefer to replace alignment components at one time in order to avoid multiple expensive alignments at the Mercedes Dealer.
Thanks guys
Old 11-27-2013, 12:22 AM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
no camber adjustment in the rear unless you put in and adjustable link which is listed in a previous post
Old 11-27-2013, 04:51 AM
97C230's Avatar
97C230
So, just to confirm, only a toe adjustment in the rear via the tie rod?
Old 11-27-2013, 08:18 AM
Boom vang's Avatar
if you want camber adj in the rear, look at this thread
https://mbworld.org/forums/c-class-w...mber-arms.html
Quick Reply: Rear Suspension Replacement and Alignments
