2002 C230 Kompressor Differential Rear Axle Fluid? Is the change ok?
So the owner's manual of 2002 C230 Kompressor calls for SAE 85 w90 hypoid gear oil.
I went to the Benz dealer and gave me SAE 75 w85 gear oil (part number 001-989-33-03-12). The receipt shows that 001-989-33-03-12 replaces 001-989-33-03-10. I also asked the clerk and I was told that it was changed.
Is it OK to use SAE75W85 oil when it calls for SAE85W90?? Am I in the clear?
The following product list should help you to select the correct operating fluid for your vehicle/major assembly from the variety of products in the market.
We are recommending to use exclusively the products listed in the following overview, because only these products have been tested and approved by Mercedes-Benz.
We recommend using only products
1.which are distinctly marked with the label indicating the approval of Mercedes-Benz, e.g. “MB-Approval 229.51”. Labels referring e.g. to “MB 229.51” don't have an approval of Mercedes-Benz.
2.Which are listed in the current MB BeVo. Only listed products are tested and approved by Mercedes-Benz.
Application in vehicles/major assemblies refer to Sheet 231.1
Select Sheet 138.1226.5226.51226.9228.0228.1228.2228.3228.31228 .5228.51229.1229.3229.31229.5229.51229.52235.0235. 1235.10235.11235.12235.13235.15235.20235.27235.282 35.29235.3235.31235.4235.41235.5235.6235.61235.723 5.71235.72235.74235.8236.1236.10236.11236.12236.13 236.14236.15236.16236.2236.20236.21236.25236.26236 .3236.41236.6236.7236.8236.81236.9236.91264.0265.1 266.0266.2267.0267.1268.0269.2311.0312.0325.0325.2 325.3325.5326.0326.3326.5331.0331.1341.0342.0343.0 344.0345.0346.0361.0361.1362.0362.1363.0385.1385.2 385.3385.4385.5
Overview
Last update: 09/02/2013
PRODUCTNAME
PRINCIPAL
MB 235.7/ 235.74 FE-Hypoidgetriebeöl A 001 989 33 03 Daimler AG, Stuttgart/Deutschland
Fuchs TITAN SINTOPOID FE 75W-85 Fuchs Petrolub AG, Mannheim/Deutschland
Mobilube FE 75W-85 Exxon Mobil Corporation, FAIRFAX, Virginia/USA
Looks good to me if this is what you bought :-
