stink air con
Old Nov 18, 2003 | 01:10 AM
c230_kS's Avatar
stink air con
my air conditioner stinks at the beginning and wait for like 5 mintues the smell is gone... if this a possible cause of faulyt air flow sensor?
Old Nov 18, 2003 | 02:44 AM
nevide's Avatar
C230 K
no. It's mold. Some people sprays lysol on the air filter to make it dissapear. I put my air con at max for 10 mins to make it go away. It does come back but not so often.
Old Nov 18, 2003 | 04:48 AM
machoman's Avatar
a Merc
mine's stinks too... any suggestion to make the smell gone forever ?
Old Nov 18, 2003 | 07:53 AM
moomeh
Guest
Posts: n/a
i have this problem as well since the beginning. since the smell goes away after 5 minutes, i do not care. but, doesn't mold have any health consequences?
Old Nov 18, 2003 | 08:18 AM
jbcritch's Avatar
Black C 240
many times the smell from an air conditioner comes from an incomplete drain of the condenser unit. (I'm no repair man but here is my best explanation - I had this done to an old car of mine to clear up smell/water problem) There is a drip tube from the condenser to the outside. You see the water under your car on a hot day? That comes down the drip tube. These can become clogged and allow water to build up and ..... mold! Any auto air shop can blow out the drip tube for you.
John
Old Nov 18, 2003 | 12:35 PM
r_liebo's Avatar
2002 E55, Black on Black
No health consequences from this particular mold. It's offensive, but not harmful. I'd be more concerned about what type of chemical you are spraying into the air filter -- fumes from many disinfectants can be harmful (although Lysol is probably pretty safe).
Old Nov 18, 2003 | 12:58 PM
moomeh
Guest
Posts: n/a
John
trip to the dealer is in order. i'm guessing there is no way i can do this myself? where is the tube exactly
Old Nov 18, 2003 | 01:04 PM
04c230ksedan's Avatar
OMG that's hilarious... I thought it was just my car.
Old Nov 18, 2003 | 01:23 PM
hobie's Avatar
'02 C230K
My dealer solved this problem. Ask them to check the TSBs.
Old Nov 18, 2003 | 01:24 PM
jbcritch's Avatar
Black C 240
Answers:
dont know if it can be done yourself....
and no....it isnt just you......
John
Old Nov 18, 2003 | 02:00 PM
mostolf's Avatar
Non-MB
turn off the AC...
I've had this happen on several cars. I try to turn off the AC (i.e., press "AC" so that the fan keeps running) a few minutes before I know I'll be shutting the car off and that usually solves the problem. Gives the condensation a chance to bake off (at least that's what I tell myself).
Old Nov 18, 2003 | 02:46 PM
SteveS's Avatar
2003 C230 Kompressor Sedan
Re: turn off the AC...
I have used this method for 25 years, and it always works. I am amazed that more of you haven't encountered this with other cars. I have never had an air conditioned car that didn't exhibit this.
Old Nov 18, 2003 | 04:48 PM
moomeh
Guest
Posts: n/a
thanks, i'll try this before i go to the dealer.
Old Nov 18, 2003 | 06:18 PM
tberry's Avatar
2002 C230 Coupe Black/Charcoal C5 C7 Auto
it usually happen more often (from my understanding) from humidity and also if you do not use your A/C often (I think its even in manual, I know it was in my Audi manual). It is mold u're smelling. I dont know about these cars but I know they make a "cleaning" kit for older a/c system.
