2002 W203 ABS BAS ESP
Hello new here and trying to get some help
i own a 2002 W203 and recently disconnected the battery got the Usual ABS,BAS,ESP Lights I've read that its the Brake light switch but there's no Brake Light Switch under the pedal or around there anybody know where else it could be Thanks |
Search on here it is up under the plastic panel
Ive removed the Plastic Panel and there's nothing
1 Attachment(s)
No switch where the switch is suppose to be
did you trun the steering wheel left and then right to reset it?
They did take the switch out at some point around 02 I believe so your car may not have one. Do you have any reason to believe the switch is bad or was that just a guess? If you have done what corkshoppe recommended and that doesn't help you really need to get a star system to check it out or at the least a code scanner.
Yes I have Turned the Wheel and nothing
as far as the scan goes ill have to check that out |
LOOK AT THE FOLLOWING THREAD
https://mbworld.org/forums/c-class-w2...-assist-visit- workshop-bas-2.html. I fixed the BAS warning by clean the brake switch attached to the brake pedal |
