K&N Air Filter
Old Nov 19, 2003 | 06:19 AM
esputmono's Avatar
K&N Air Filter
How many airfilter do i need to replace? is it 2 ?
and can someone tell me how to open the engine cover?
Thanks in advance.. :p
Old Nov 19, 2003 | 07:02 AM
mrchocolatte's Avatar
c 320
its two..... right and left.
all i know is remove the two air flow front pipe.
but i might be wrong.
sorry.
Old Nov 19, 2003 | 08:09 AM
moomeh
Guest
Posts: n/a
don't these filters cause problems with certain sensors in the car thereby decreasing performance after a couple k miles?
Old Nov 19, 2003 | 08:25 AM
MB///HRV's Avatar
There has been talk about the oil used to condition the gauze can damage MAS sensors.
Old Nov 19, 2003 | 11:49 AM
esputmono's Avatar
so replacing the stock with K&N can decreasing performance?
esputmono's Avatar
Old Nov 19, 2003 | 12:32 PM
moomeh
Guest
Posts: n/a
i've read several threads about cars, eg c43 or c36, not up to par in performance like when they were new. several members commented about how k&n filters seems to release an oil over sensors that detect the correct amount of air/gas ratio needed for the engine to combust fuel correctly, thus hindering performance. people reported clean the sensors or getting new one and the performance going back like the car was new again though.
Old Nov 19, 2003 | 02:21 PM
MB///HRV's Avatar
The only way to let more ait in throught he same surface area is to increase the space between fibers. If you increase the space between fivers then you are also increaseing the space for more dust and particles to go through. And im sure you can guess where the next stop for these particles will be... A good thing to compare is the size (in microns) of particles the filter will let through. FOr insnstance i think BMC will let less dirt though than the K&N. They use a foam instead of gauze which is supposed to trap moredirt and be more effecient than tthe K&N.
Old Nov 19, 2003 | 07:13 PM
C klass 320's Avatar
2004 C 320 4-matic
i think itg air filters are suppose to be the best ones availible....
Old Nov 19, 2003 | 07:23 PM
MB///HRV's Avatar
My apologies, too many things going on at one time. BMC has the gauze as well, itg has the foam filters.
Old Nov 19, 2003 | 07:47 PM
2004 C 320 4-matic
yeah i also heard bmc are great although i think one of them or both contain oil but its a minimal amount compared to the K&N which is saturated.... not good when your at high speeds accelerating the air is coming in so fast and being sucked in at the same time all the oil is bound to be on your sensors.. i wouldnt go with K&N... some people may like them and just shake all the excess oil off and use a towel so theres not as much but in my opinion there dangerous..
