::ECS Tuning:: W203 C230 H&R Coilover Kit
Click HERE to order or for more information.
Only $1185.95*
H&R Street Performance Coil Overs are the perfect suspension solution for discerning drivers who can appreciate the awesome handling and superb ride comfort. Each coil over shock is custom valved to work in conjunction with a precision-engineered progressive rate spring, creating a finely tuned suspension system. The fully threaded shock body allows for adjustable vehicle height. This feature helps balance vehicle weight, resulting in a lower center of gravity and improved performance and control.
H&R Street Performance Coil Overs are precision-engineered and manufactured in Germany, so you know that when you install H&R suspension components on your vehicle, they will last for years to come.
This set of coil overs will lower your Mercedes-Benz between 1.2'' to 2.2'' in the front and 1.0'' to 2.0'' in the rear.
If you are replacing your standard shocks, struts and springs with this H&R Street Performance Coil Over kit, now would be a great time to inspect the rest of your suspension system and replace any parts that are showing signs of wear. ECS Tuning offers a complete line of suspension components for your Mercedes-Benz, so you will never have to compromise when it comes to ride quality or driving dynamics.
*Price subject to change.
No, the coilover kit is not specific to C230 models. The coilover kit will fit the following cars:
C230 (2002-2007)
C240 (2001-2005)
C320 (2001-2005)
This kit is for rear-wheel-drive cars only, and will not fit cars with 4Matic.
If you have any other questions, please feel free to post or send a PM!
No, this kit does not fit the W209 cars. This kit only fits the following vehicles:
C230 (2002-2007)
C240 (2001-2005)
C320 (2001-2005)
There are W209 coilover kits available on our site. You can get to our site HERE and then find the coilover kits by selecting your year, make and model. Then go to Suspension --> Coilovers on the menu on the left side of the screen.
If there is anything else I can help you with, please feel free to post or send a PM!
The one thing to keep in mind is that with Coilovers you have the ability to adjust the ride height.
We are in Northeastern Ohio, and know exactly what you mean about the winters getting nasty at times. Having a car that has a low ride height that cannot be adjusted can mean big trouble if you get caught in a blizzard.
My advice would be to go with Coilovers and when winter comes, crank 'em all the way up, throw on a set of good snow tires, and drive with confidence.
We offer Coilovers for your car from some of the best manufacturers. You can get to them on our site by clicking HERE, or by clicking on the photos of the Coilovers below.
I hope this information helps you make a decision, and if there is anything else I can answer for you, please feel free to post or send a PM!
Thanks again.
Thanks again.
Any time you lower a car, you are going to change the ride quality. A lower ride height means less travel in the suspension, and the stiffer dampers used when lowering a car do not improve the ride. They will, however, improve the driving dynamics of the car.
Coilovers can be a bit bouncy, but this can be changed somewhat with raising the ride height until you feel the ride improve to your satisfaction. Coilovers like the Bilstein PSS9 System for you car a fully adjustable. You can adjust the ride height as well as the valving on the dampers to dial in the perfect ride for you.
As far as the Spring and Shock combo being smoother, this is subjective. It really depends on which parts you choose. If you go with H&R Springs, but use stock shocks, you will get a somewhat smoother ride, but the shocks will not last as long as they would had you used shocks that are designed for lowered cars.
A shock / strut like the Bilstein B8 Sport is valved to be stiffer than stock, and also has a shortened shaft to accommodate lowering springs.
As far as additional components that you would need when installing this, I would, at the very least, change the front strut mounts during the install. If you are going to put coilovers on your car, don't use your old, worn out strut mounts.
With wheel fitment, the need for spacers, etc... This is again subjective. Depending on how much you are going to lower your car, you may need to roll your fenders to prevent rubbing if you are running a larger than stock wheel. This is something that will have to be determined by you during the install because this is all based on how big your wheels are, how low you want the car, and whether you go for springs / shocks or coilovers. If you want the flush look, spacers will be the way to go, but this can affect fitment, and require changes be made to ride height, and the fenders. This really comes down to what you want your car to look like.
I hope this info helps shed some light on this for you, and if there is anything else I can help out with, just let me know.
Honestly, if it were my car, I would go for the H&R Coilovers. They are reasonably priced for a high-quality product, and give you the versatility you will need to raise and lower the car. Since this car is a year-round driver, you will be glad you are able to lift it up a little in the winter.
The ride the H&R Coilovers provide is just fine for daily use, and you will definitely notice an improvement in handling.
I would replace the Front Upper Strut Mounts while doing this job, since the only time you will have access to these is when you have the struts removed.
I hope this helps in your decision making process. If there is anything else I can do, let me know.
