HID busted???
Old Nov 29, 2003 | 07:14 PM
Jorel C320's Avatar
2001 C320
HID busted???
Darn...my right HIDS wont turn on. I bought it with the group buy that Jason did a couple years back. At first it took a couple on and offs for it to go on, and now, its just dead. Dont know what to do cuz its aftermarket?? Not sure if its the connection...the bulbs..etc. Any advice???
Old Nov 29, 2003 | 08:01 PM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
It happen on one of my Bi-Xenon unit. When I just got it, the light will turn on with 5-30sec delay but after few weeks it went dead. I talk to Steve and he managed to replace the whole unit for me. Later he found out the igniter unit is bad and he is able to fix it.
If ur bulb is not broken, the only 2 possible unit that may brake down is igniter or blaster.
Old Nov 29, 2003 | 09:54 PM
Jorel C320's Avatar
2001 C320
So where or who should i go to for a diagnosis???
Old Nov 29, 2003 | 11:18 PM
VERSUS's Avatar
03 C32
It happend to my 03 C32 too~~ my right Bi-exnon sometimes won't start~
first my dearler said its the problem with some parts inside but after they replace the parts...still doesn't work...
now they are ordering the new head light for me.....and it happend to some other w203 bi-exnon owner too~~
Old Nov 30, 2003 | 12:18 AM
DL_AMG's Avatar
Just upgrade to Bi-Xenon (from Steve) and keep it as a spare (& see if Steve can take a look when he is here again.)
Just a suggestion.
Old Nov 30, 2003 | 04:30 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Re: HID busted???
One of the downsides of aftermarket...
greetingz,
Old Nov 30, 2003 | 06:19 AM
Jorel C320's Avatar
2001 C320
I was talking to my friend and he said that is the downsize to most HIDS. Since they are fairly new technology, not much research is out yet, and thier is alot of cases that one side dies right away. I guess im pretty much screwed!
Old Nov 30, 2003 | 04:46 PM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Depends on the bulb quality.
Even OEM Xenons blow every once in a while.
I've known people who have aftermarket kit for years without a blowout.
BTW, you can pick up a set of HID Bulbs from $99-200 easily.
Erik
Old Nov 30, 2003 | 05:33 PM
Jorel C320's Avatar
2001 C320
Thanks guys. I guess i just need to find out if they really are busted. Hope its obvious like regular bulbs.
Old Nov 30, 2003 | 10:11 PM
tifosiv122's Avatar
Just swich bulbs...if it works on the other side, then its not the bulbs.
Erik
Old Nov 30, 2003 | 10:14 PM
peet's Avatar
09 C63
I don't want to overstate the obvious... but why not switch ballasts and bulbs to deduce which component is bad? You did get two right? This way you will be able to definitively state this is the bad component. How to get it repaired/replaced - that you're on your own.
Also, HID on cars have been around for about nine years. That's not a new technology by any stretch. Most HID systems out today are 3rd, 4th gen designs. In fact, HID is becoming "15 minutes ago" very rapidly. A quick scan of all the new cars on the show circuit will tell you that all the manufacturers have a woody for LED lights - yep little round buggers that we all have everywhere. Also, fwiw, HID has been around (outside of cars) since the 1930's.
Peet
Old Dec 23, 2003 | 01:38 PM
Jorel C320's Avatar
2001 C320
Dude...the shop that installed my HIDS made it so hard to take it out. The plastic cover was hard to take out due to the ballast blocking the way...then the wires that run through the cover make it difficult to find room to stick my hand in there. Once i get room, i cant even take out the bulb (whats up with the bulb...shouldnt it come out like a stock one or is it one piece??). Thats where i am now. MAN. I feel like taking the whole system out and going back to stock. Sorry, im just frustrated right now.
Old Dec 23, 2003 | 01:47 PM
tifosiv122's Avatar
Your asking questions that will varry depending on who installed it and which kit it is.
Personally, I know my kit all I need to do is remove the headlight cover (the circular screw part) to get to the bulbs...10-20 seconds at the most.
Erik
Old Dec 26, 2003 | 01:32 AM
Richard Galing's Avatar
W210, W220, W163, W164, C6
Have you checked the R headlamp fuse...my kit came with a bad relay and upon installation blew the fuse.
Good Luck
Richard
Old Jan 19, 2004 | 03:32 PM
Jorel C320's Avatar
2001 C320
Well...I switched the bulbs and its official...the ballast is not working. Any ideas on what i should do. Is it worth trying to find out if i can buy a new ballast? or should i just go back to stock?
Old Jan 19, 2004 | 03:49 PM
tifosiv122's Avatar
Get a new ballast on ebay...stock sucks.
Erik
