srs faults cleared warning light still on
Old Jun 28, 2014 | 08:51 AM
carll215's Avatar
c220 cdi sport coupe
hi i had the srs light on on my 2003 c class coupe. i had the fault code read on autel diagnostics machine, it turned out it was the curtain airbag squib. i have replaced it and the code has no been removed, the car is showing no codes atall. however the srs light is still illuminated on the dash and the srs warning in digital display. very confused, thanks
Old Jun 30, 2014 | 07:33 PM
samaritrey's Avatar
Super Moderator
THE C350
I am not familiar with the autel diagnostic machine but I suspect you need to make sure it is capable of Mercedes diagnostics. I would find someone with the Mercedes diagnostic computer to verify issue is fixed and reset the system to see if that fixes it. I have heard srs lights are hard to reset but I have a star machine so I haven't tried using other systems.
Old Jul 7, 2014 | 12:48 PM
carll215's Avatar
thank you for the reply, i shall get it booked into somebody with star, hopefully this will rectify the issue. thanks again
