Help--dealer couldn't diagnose...
1995 Acura
I've got a C230K with the Bose system. I wanted to have both the speed-sensitive audio system and the Bose AudioPilot shut off. The folks at the dealer (RAB Motors--Marin) set the speed-sensitive setting to "off," but couldn't find anything for audio pilot. The system is definitely still adjusting the audio levels. I actually stood there while he had the laptop connected to my car, but he couldn't find it, and said he knew nothing about any feature that listened to cabin noise and adjusted audio levels. Can anyone give me a concise description of what to tell them? Thanks in advance!
What is Bose Audiopilot? Also, is the amount that the speed sensitive volume adjusts volume adjustable? errr, that was an awkward sentence but basically it seems to quiet the volume just a BIT too much when I slow down.. probably not worth picking over.
'05 c240 4matic wagon
Originally posted by columbus
I thought they were one and the same - AudioPilot = speed-sensitive volume control
sfvideoguy, you may be stuck w/ it... when i contaced bose, they said it could be turned off but i'd have to contact merc to find out how (they don't know... )
1995 Acura
Actually I saw the DAS screen that said "speed-sensitive audio system"--and he set it to "off." It was the AudioPilot that he couldn't find. As I understand it, speed-sensitive audio is exactly that--it adjusts audio levels solely based on speed. Audio Pilot is supposed to actually listen to cabin noise (an open window, a screaming child...) and adjust audio levels so they stay constant. Do MBTech or Adam know???
C230 C-Coupe
Yesterday I heard a static crackling noise from my standard stereo system. I turned the stereo off and on and have not heard since.
Has anyone else experienced this type of distortion. Obviously if it comes back I'll be taking it in but just interested if anyone knows of a problem there?
Nathan
Nathan
