stuttering on hard acceleration
Old Nov 28, 2014 | 09:59 PM
C_steapsC230's Avatar
2002 c230 kompressor coupe, 2005 c230 kompressor
OK so I have a 2005 c230k ss with the m271 automatic and I like to drive my car rather hard and for the second time I've gunned it at a red light and it'll go hard then reach about 4-5k rpm in first, stutter, then the check engine light comes on. Then my engine is shaking a little more than usual so I turn my car on and off then it runs fine but the light is still on. The first time it happened I changed spark plugs and reset the light and it was good but now I'm stumped anyone got any idea of what could be wrong
Old Nov 29, 2014 | 04:08 PM
Glyn M Ruck's Avatar
Super Moderator
Get hold of an OBDII scanner & see what codes are being stored.
Either fuel starvation or ignition breakdown likely.
Check fuel pressure at the Schrader valve on the front fuel rail. s/b >3.8bar or 55psi while cranking. When last did the car have a fuel filter.
OBDII readings will tell you if you have a bad coil etc.
Old Nov 29, 2014 | 04:32 PM
Alright just got the codes P0304 p0171 p0128 and Idk about fuel filter only had the car for 8k miles my car has 90k total miles
Old Nov 29, 2014 | 07:28 PM
Super Moderator
P0128 = Need a new thermostat ~ car is running too cold
PO171 = System too Lean (Bank 1)
PO304 = Cylinder 4 Misfire Detected
While you might have a MAF problem, next thing to check is fuel pressure. Fuel trim is too lean. She is starving of fuel.
Replace the thermostat.
Check plug & coilpack for cylinder 4.
Old Nov 29, 2014 | 08:03 PM
Thanks man I think I'm just gonna take it to the stealership what do u think they will quote me? My work schedule is crazy and she's my daily driver or else I'd do it myself
Old Dec 1, 2014 | 10:59 PM
Car is at the dealer! As soon as I get the diagnosis I'll let ya guys know for those who care
