Transmission DIPSTICK Question
Old Feb 10, 2015 | 07:20 PM
scottonfire's Avatar
2013 c250
So the range on the dipstick is 25 degrees and 80 degrees. My car runs closer to 90. So when I'm measuring the level when my car's hot, do I wait until it goes down a few degrees or measure it when it's closer to 90. In that case, I would THINK that the level should show that it is overfilled by a little bit since the hotter the temperature, the higher up the level goes. Are you with me?
Old Feb 10, 2015 | 07:25 PM
RCPDesigns's Avatar
2007 e350, 2013 C250, 2004 C320, 2003 C320, 1998 CLK 320
Where are you measuring the temp and getting 90? The engine temp is not the same as the transmission temp. Apologies if you knew that already.
Old Feb 10, 2015 | 09:19 PM
2013 c250
I assumed that the degrees on the dipstick corresponded to engine temp since that is readily readable in my car. I guess that's what the IR gun's for. Crap.
Old Feb 12, 2015 | 06:42 PM
jkowtko's Avatar
2005 c230SS
The "80 degrees" is just referring to "full operating temperature". Get the tranny fluid as hot as it's going to get under normal driving, and that is the level you want to check.
