Fitting 19 inch wheels w203 2001
Old May 11, 2015 | 08:16 AM
vagosvisk777's Avatar
c200 w203
Question Fitting 19 inch wheels w203 2001
Hello guys I am new here and I need your help. I want to fit 19 inch wheels to my Mercedes Benz w203 4door sedan C200 Kompressor model 2001 and I need some information. I am thinking about Mercedes genuine rims and tyres size 265 30 19 rear and 235 35 19 front. What should i check before buying? Is there any issue with fenders? My suspension is stock. Should I choose specific ET or there is no problem? Thank you in advance.
Old May 11, 2015 | 05:13 PM
Mr Shant's Avatar
2007 c230
Not sure on the sizing and all but I have 19's on my 07 c230 that are for sale now.
Wheels and tires all for $600
SoCal area
Old May 11, 2015 | 06:06 PM
c200 w203
What are the specs of those wheels?
Old May 11, 2015 | 06:43 PM
Mr Shant's Avatar
2007 c230
I am waiting for my stock wheels to arrive any day now, just found a set in Az.
Here's some info for now...
Set up is staggered with 19 x 9 1/2 rears and 19 x 8 1/2 fronts
Bolt pattern is 112mm
Rears offset are et 35
Fronts are et 32
Tires, The two front are Nitto Extreme ZR 235/35/ZR19 and the backs are both General GT GMax 265/30/ZR19
All four wheels are in very good shape (very minor scrape on two wheels) and all four tires are in very very good condition (back two are almost new).
All lugs included
Old May 11, 2015 | 07:44 PM
c200 w203
Did you have to make any modifications to fit these wheels?
Old May 11, 2015 | 08:03 PM
Mr Shant's Avatar
2007 c230
I just bought the car last week and have only driven it on a test drive, to the mechanic one block away and same to the smog shop. Car is sitting in my shop for the stock wheels.
I'm not sure if there are any spacers behind them? Soon as the stock wheels show up, these will be taken off and I will have this info and more.
Are you in SoCal?
Old May 11, 2015 | 08:11 PM
c200 w203
No my friend I am in Europe but I would appreciate it if you could help me with this information
Old May 11, 2015 | 08:49 PM
Mr Shant's Avatar
2007 c230
Ok soon as I get these wheels off I will report back with all the right info.
Wheels sit and look perfect on the car, it's just that I don't know what's behind them. Few more days.
Old May 12, 2015 | 01:15 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Mr Shant, mind sharing your strategy of searching for stock wheels? I haven't had much luck in that regard... Thanks!
Old May 12, 2015 | 01:29 PM
Mr Shant's Avatar
2007 c230
Click the link below. I just put in the search bar "Mercedes Wheels or Mercedes Wheels 17" then hit the "Sort By" button to the right to "Date" (that brings the newest posts to the top.) Just go through the pages from there. Good luck!
http://www.searchcraigslist.org/
Old May 12, 2015 | 01:42 PM
VVF's Avatar
VVF
Thanks!
Old May 13, 2015 | 09:22 PM
Mr Shant's Avatar
2007 c230
Ok here is the wheel in for for my 07 c230 sport
Front wheels are 19x8 1/2
Rear wheels are 19x9 1/2
Ok stock wheels came today so I have the offset into
Fronts are et 32 and the rears are et 35
Wheels look great on the car they sit well with no rubbing. Perfect set up for some one that wants to go up in size to 19's. Hope that helps.
Mr. Shant
