2006 C280 Sunroof issues
Old Oct 3, 2015 | 08:36 PM
silentbob's Avatar
2002 ML 320, 2006 C280
I just bought a 2006 C280 4Matic and love it.
But I have a few sunroof issues -
This (wind blocker??) does not come up when the sunroof opens.
I found these parts - spring and plastic tab on driver's side and plastic tab on passenger side in the track area as well as some pieces of the seal that I will have to replace.
We got the first heavy rain and it leaked into the cabin. I did find a link to how to clear the drainage channels if this is also contributing to the issue.
Is there a parts list for the sunroof someone can give me the link to?
Also, when you hold the button to close there is no problem but when I try to use the auto close it gets within an inch of closing and opens about 30% of the way. is this a sync issue?
Thanks for the help in advance.
Old Oct 6, 2015 | 09:13 AM
BF_JC230's Avatar
2005 w203 C230
Where did it leak? If the front corners...there is a TSB on this - and a replacement/fix with an installed Butyl cord. Dealer should be able to just "drop" headliner - not remove - to install.
YES...EPC will be a GREAT resource for you. Sign up!
Keep those slides clear and lubricated, lightly, with OEM "grease"/paste.
...ensure you place it correctly.
Keep the drains clear...
https://mbworld.org/forums/c-class-w...p-out-car.html
https://mbworld.org/forums/c-class-w...lubricant.html
