Air intake hose split/cracked
Old Nov 25, 2015 | 05:12 PM
Jack_12's Avatar
2002 c320
Hello everyone. I noticed that the right passenger side engine air intake hose on my car(2002 c320) is almost split in half and about to fall apart. It's one of those plastic ones. The part number is A 203 528 00 07. I have a few questions.
Will it cause any damage to the car if i don't get fixed soon? Also, do both sides need to replaced at the same time? I don't know much about cars. So, i think it's better to have a mechanic take a look at it, if it's something that needs to replaced right away. How much should the part cost including labour?
Might try to replace it myself, if it's easy. If someone has a link to a DIY for this issue. Could you please post it.
Thank you.
Old Nov 26, 2015 | 01:58 AM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
No, it won't cause any damage.
You can just replace the one that's split if the other is fine.
Just google the part number and compare the prices.
The part that goes toward the front of the car has holes on top/bottom that hook to the support (see pic). All you have to do is carefully pry them off the hooks and the hose will come off.
Attached Thumbnails Air intake hose split/cracked-s-l1000.jpg
Old Nov 26, 2015 | 07:50 AM
johnhef's Avatar
83 500SEC, 87 300D, 02 C32(x2), 02 C320T (x2), 03 C320T4, 03 C320T, 03 E55, 05 E320CDI, 06 E320CDI
Probably one of the easiest DIYs you can do. I just replaced them both on our C32 and was surprised to find how cheap they were. About $14 each. Good luck Jack!
Old Nov 26, 2015 | 02:33 PM
Jack_12's Avatar
2002 c320
Thank you VVF and johnhef for helping me out. I really appreciate it. Replacing the air intake hose will be much more easier for me now. I will try to find one for a good price.
Thanks once again. Have a great day.
