C240 Antenna/Key Fob Issues
Old Jul 20, 2016 | 02:32 PM
Kash5983's Avatar
2002 C240
Sorry if this topic has been covered already, but I couldn't dig up anything that might confirm my suspicions. I just bought an 02 C240 and the radio works but it's not picking up a signal (it is the model with the flip down cassette player). The roof antenna is missing which I believe is the tele aid antenna), but I was unsure if that is the same antenna that the radio uses. I'm also curious if that same antenna works with the key fob, as I just changed the battery on the key fob and nothing happens (the auto door lock buttons inside the car do work)?
Does anyone have any suggestions on what I should check and/or replace to get both issues fixed?
Old Jul 21, 2016 | 11:25 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Key fob works off a different thing; the issue is probably in the door handle. Do a search for it, the solution is a real PITA.
The antenna is in the rear glass, so it's also separate from the Tele-Aid sharkfin. Probably disconnected either on the radio end or coming from the glass.
Old Jul 24, 2016 | 05:47 AM
Glyn M Ruck's Avatar
Super Moderator
https://mbworld.org/forums/c-class-w...hlight=Antenna
Amplifier mounted above rear screen on some cars.
