W203 - Front and Rear Flex Disk Part number??
Old Jul 25, 2016 | 06:25 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
been reading up on these Flex Disks from the C32 boards and couldnt find my answer so hoping someone here on w203 might know....
i think my Front and Rear Flex disks need to be replaced as i have some pretty bad vibration when in gear and when in idle my engine vibrates like crazy. i already replaced the motor mounts, trans mount, plugs & wires and nothing has fixed this.
would next logical check be of the flex disks as the culprit?????
what is the correct part number for those?
dealer 6 years ago changed my rear and used part #230410015 but doesnt come up on several MB parts sites as the correct one for C32.
most of the MB parts sites list these parts for Front and Rear so assuming these are the new/correct numbers for front and rear??
2034100215 - REPAIR KIT REAR $83 bux on parts.com
2034100447 - REPAIR KIT FRONT $172 bux on parts.com
thanks!
Old Jul 26, 2016 | 02:32 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Just hit the dealer with your VIN and they'll be able to locate the latest part #. MB is notorious for this. The same part will have 5 different part numbers depending on when it was made.
Not sure if the V6 has a vacuum brake booster pump at the back of the engine, but this is a major source of vibration for the I4 engine at idle. You might want to look this and see if your car has one, and also see if it's leaking engine oil (also common in the I4).
