Help needed to remove the "seal" right underneath the bottom edge of the door?
? Thanks.
.The rust area I want to fix
The "seal" at the bottom of the door
Mine is a 2005 with 250K Km on it. My daughter drives it to college now. It is rusting, particularly the dogs legs. (Montreal salty winter roads) I wont do any body work. figure give it another 5 years. and it will have done its faithful duty.
However, the donor door has the strongest weirdest tackiest glue I’ve ever come across. I could not locate the OEM remover at a 1 door DIY quantity - I tried prepsol, prekleeno, BESTINE, alcohol, mineral spirits, acetone, 3M adhesive remover and there are still tracks of glue/sealant. Seems very CNC applied and almost seems to be an added sealant at the crimped rolled bottom edge.
Anyone ever get all of this goop off?
I’m about to just install the bottom door seal per WIS by filling the channel with adhesive...after I tape off the exterior of the door, just in case, certainly not how it was done in Sindelfingen.
