Hard starting - no fuel pressure
Old 02-15-2017, 11:46 AM
sofo_bogdy's Avatar
W203 Mercedes C180k
Hello friends! I am the owner of a Mercedes C180K W203! For almost a year I have problems with starting.I have a long crank and finally the car starts.Today I have made a pressure test and with the ignition on the pressure is about 47PSI but right away it drops to 0 PSI.When I turn the key and starts cranking the pressure rises slowly and when the pressure reach about 45 PSI,the engine starts.I shut off the engine and pressure drops to 0 . I put a link with the test:
Any advice is important to me.Thank you!
Old 02-15-2017, 08:44 PM
RWDlifer's Avatar
2005 C230K SS
Looks like your fuel system is not holding residual pressure, may be the fuel pump dying or very clogged filter as you said...assuming you have no leaks..
Old 02-16-2017, 01:48 AM
sofo_bogdy's Avatar
W203 Mercedes C180k
The fuel pump is new, so I am sure that it is not the problem. If the fuel pressure regulator on the rail goes bad, can he drop the fuel back in the tank?
Old 02-16-2017, 01:59 AM
ItalianJoe1's Avatar
2003 CL 600
Bad regulator. I believe on that system it's part of the fuel filter. The check valve that holds pressure when the pump is off is failed.
Old 02-16-2017, 02:18 AM
sofo_bogdy's Avatar
W203 Mercedes C180k
I know for sure that I have the fuel pressure regulator on the fuel rail. I will try to replace it and hope the start problem will go as away. Thank you!
Old 02-22-2017, 06:42 AM
sofo_bogdy's Avatar
W203 Mercedes C180k
Today I had replaced the pressure regulator on the fuel rail but the problem was not solved.I will try to change fuel filter,I will buy MANN WK 720 fuel filter with integrated pressure regulator.Hope that will solve the issue.
Old 02-23-2017, 02:08 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Pump was replaced? Perhaps it's faulty.
New? from where? China?
Always go back to the last you did.
Old 02-23-2017, 02:27 AM
sofo_bogdy's Avatar
W203 Mercedes C180k
Fuel pump is new! I replaced it 3 months ago.
Old 02-23-2017, 06:29 AM
Super Moderator
Glyn M Ruck's Avatar
What year is this car. Does it have an external fuel filter or an in-tank unit?
Old 02-23-2017, 09:20 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
did you even read the post above this one?
Old 02-23-2017, 02:10 PM
sofo_bogdy's Avatar
W203 Mercedes C180k
The car was made in 2003. The fuel filter is external. It is located under the car, close to the rear left wheel.
Old 02-23-2017, 03:53 PM
Russell Ormerod's Avatar
not a merc
You know for sure that the regulator is on the rail! Except you are wrong. It's in the filter. There are only 2 ways your problem can occur.. bad pump or bad filter.. or a 3rd option. Bad workmanship when u replaced the pump.
Good luck
Old 02-23-2017, 10:03 PM
Good luck
Precisely my point.
Old 02-23-2017, 10:20 PM
Glyn! You old tart! Nice of you to drop into the Mercedes W203 ghetto....
ha. Even my lady was asking about you....no joke!
Is there a 'lady's man' reputation I don't know about spreading all the way from the Dark Continent to my humble abode?
(As it was called by author Henry M. Stanley for it's mysterious and largely unknown features in the 1800's.
Figured I'd better qualify the term for all the uneducated heathens out there
who might mistakenly take it for something derogatory. )
Old 02-26-2017, 01:22 AM
not a merc
C230 coup, I am also at the bottom of the dark continent. No worries we all good here, except for a lack of water.
Old 02-27-2017, 03:24 AM
sofo_bogdy's Avatar
W203 Mercedes C180k
The problem was solved with the replacement of fuel filter.With MANN WK 720 filter all is ok!Thank you!
Old 02-27-2017, 06:26 PM
Ah. Well, definitely something that should be done in tandem with a FP if the filter hasn't been replaced recently. Every 60K miles according to MB. Probably why the old pump broke.
