Relearning air recirculation flap M111
recently I got code P0410 on my C200 Kompressor, 2001 (M111 engine). I already made sure 2 valves (to the exhaust) for recirculation are functioning well and no leaks in the vacuum system.
Now I want to try to relearn the Recirculation Flap on the intake. I found procedure on a few forums, but I don't understand the process. Could someone here explain me in simple words how it is done?
1 When ignition is switched off press flap slightly past limp home
position. - IS THIS HORIZONTAL OR VERTICAL (open or closed?)
90° position must be changed manually. The processor
shut-off delay has a duration of approx. 5 seconds. (IS THIS THE NEXT STEP OR EXTRA INFO??)
2.Switch on ignition for approx. 15 seconds, switch ignition
back off again and wait for processor shut-off delay.
3. Switch ignition on for approx. 45 seconds, switch ignition
The learn-in procedure for the recirculated air flap is then
completed.
Help me please!!
If this doesn't work, should I buy a new flap? Or other suggestions? Clean throttle body? O2 sensors?
a replacement air flap. As a new one lists for ~ $1500 look for a used one.
Just did this recently. Got lucky, pulled from Picknpull but with traffic it took a while,
yard was 60 miles away. Problem solved.
New problem, recent rains killed my instrument panel.
Waiting patiently for another coupe to appear at the picknpull.
When you manually change the position of the flap, and someone else turns the key to position 2 for 15 seconds, do you keep holding the flap? Or let go as soon as the ignition is on?
another member pointed me towards another thread where it is explained as follows:
Do the following. (from service DVD)
1 When ignition is switched off press flap slightly past limphome
position.
90° position must be changed manually.The processor
(Which mean, just physically push it a little out of it's normal position when off, while someone else turns on the ignition in step 2)
2 Switch on ignition for approx. 15 seconds, switch ignition
3 Switch ignition on for approx. 45 seconds, switch ignition
completed.
However still doesn't answer my initial question.
The used one I bought was working great....
but my intrument panel died due to the rain.
Got it working again! Hurray! Got my guages bak!
And immediately the used recirc flap part failed spewing codes...
It's always something.....new one if like $1500 so won't be doing that....
patiently waiting for another 2002 C230 to show up the pick and pull.
236K miles and counting...
blowing out of the intake.
Incidently, either of these pn's works.
Partsgeek has it for ~$350. NEW!
A1110980109= Air Recirc Supercharger 1110980050
