Undocumented REST feature?
Old Apr 6, 2004 | 08:16 PM
kokketiel's Avatar
'01 ML430, '03 C320 Coupe MT, '14 GL450
We have a 2003 C320 Coupe. It does not have the AC with the digital readout, and hence no button with a "REST" label. However, if the car is off and I hit the "auto" button, I can hear and feel the AC fan come on and blow warm air. Is this an undocumented REST feature? My manual only mentions REST for the more fancy AC.
Old Apr 6, 2004 | 08:51 PM
silberrosa's Avatar
Yes, this has been discussed many times.
Old Apr 7, 2004 | 08:19 PM
pokerFACE's Avatar
it's supposed to be a leftover feature. REST was taken out by costcutting. but i suppose they already started using the new plates before the actual unit was updated.
Old Apr 7, 2004 | 08:28 PM
kokketiel's Avatar
Thanks for the replies...
I did a search of the forum, after the post above, but only found one thread where this was mentioned. So it looks like we lucked out with the REST feature. We had it on our SLK and CLK and kinda got used to it.
I hate it when these little features disappear over time to make it look like the car prices are staying the same! Our earlier MBs had hard cover manuals, and now everything is paperback. In our new CLK Cabrio that we bought last year, they left out a bunch of features that were present in the previous model, e.g. seats that glide forward electrically for access to the rear seats, power rear headrests. They even left out the plastic bag in the boot for your flat wheel when you have a puncture. Only two keys (our '01 SLK had 4 keys), and the list goes on...
Old Apr 7, 2004 | 08:49 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Re: Undocmented REST feature?
This fan is not used exclusively for AC, though. It is the same fan that blows warm air when AC if off.
Old Apr 8, 2004 | 09:51 AM
mctwin2kman's Avatar
Mine has the Rest Feature, just not the label on the button. I do not understand how deleting this would really cut costs. Since it is most likely just programming. I also get the moonroof and windows to close as well bu holding one button. Which was not supposed to work the moonroof in the coupes, but it does in mine. I think the most likely reason for all this is to make the C class more diferent than the 'Higher End' ones. But for those of us who know about it we get to use it.
Old Apr 8, 2004 | 10:25 AM
Nola's Avatar
Super Moderator Alumni
Audi A5 Sportback + Cannondale Prophet
Is there anyone who does NOT have the hidden rest feature?
Old Apr 8, 2004 | 12:23 PM
SteveS's Avatar
2003 C230 Kompressor Sedan
I guess I don't understand what the purpose of the rest "feature" is. Why do I want warm air blowing on me when the car is not running?
Old Apr 8, 2004 | 12:50 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
To keep the car warm for a bit while you run into the store to do some shopping. Its nice to have in the wintertime.
Old Apr 8, 2004 | 05:04 PM
electromethod's Avatar
Honda Grom
yah... andy is right... it's pretty useful... especially here in florida . brrrr.... it's a freezing 78 degrees . lol.
Old Oct 18, 2008 | 07:41 PM
acr2001's Avatar
2012 C300 4Matic
I know I'm bringing back a VERY old thread but I think it's better than creating a new one.
Apparently my 05 does not have the hidden rest feature, but when I have the key in 'run', engine off, and heat on I notice that there is a small pump next to the coolant tank running.This pump only runs if the climate control is calling for heat. I assume this is the aux pump?
Why would my car have this pump but no rest function? It seems to me like they removed the function in software but left all of the hardware so you do get a sort of 'rest' feature if they key is in while the engine is off. Weird.
Old Oct 18, 2008 | 08:06 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by acr2001
...a small pump next to the coolant tank running..
I remember reading somewhere that coolant is circulated through the engine after it reaches operating temperature so all parts of the alloy block and heads cool at an even rate. This keeps the metal from distorting and stressing at certain places. Anyone know for sure?
Old Oct 18, 2008 | 08:27 PM
acr2001's Avatar
2012 C300 4Matic
I doubt it because this pump was not on after I turned the engine off unless the climate control was calling for heat.
