W203 noise???
c200 kompressor sports coupe w203
W203 noise???
Hi I'm new to the site and looking for answers about my 2002 w203 sports coupe. There is a noise coming from under the armrest area, it seems to be there a lot more lately than before either that or I'm noticing it more lol. Anyway as u drive it has like a rubbing/clicking or tapping noise that sounds almost like heatshield or something catching on the driveshaft or something. It speeds up as I speed up and slows down as I slow down, it seems to go away if I turn left around a bend but sounds worse as I turn right. The car drives as it always has which is perfect but the noise is driving me f**king crazy. I had the lower control arms done a few months ago and seem to have had this since but I don't think it was as noisy as it is now.
Any help would be much appreciated as it's really annoying.
Thanks in advance.
Thanks in advance.
That's what I thought, thanks guys time to get her up in the air lol. Perfect drive just annoying sound. Only got 66,000 on the clock and always been looked after, had a new gearbox and torque converter last year so I was sure it was minor and I have confirmed what I thought, thanks
Mercedes C220 CDI Avant Garde SE Estate (2004)
Great, thank you :-)
After reading a few of the other posts on here and after doing some more careful listening, the heatshield/insulation hitting the driveshaft theory is sounding more and more plausible.
Good luck with your investiagtion; I'll await your findings with interest :-)
Found my problem 👍
Ok so I took my merc into my mates garage who found that she he noise was actually the rear passenger side brake shoe rattling about. Basically the shield behind the brakes had split and broke where the spring anchors itself into, which meant the spring that holds the shoes in place had lost its anchorage so the shoe was just loose inside the drum which was rattling about. Luckily these metal guards are only £40 from the main dealership so it's a pretty cheap fix. I hope this helps u in ur quest to find the noise 😊👍
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
the part will be cheap but the fix will be quite involved as I believe the drive shafts need to be taken out as well as the complete braking system just to get the shield off and on. I have the same issue as the hole that holds the lock-down springs has rusted slightly to a much larger hole and the spring has nothing to grab on to. Trying to find an easier fix with a washer or tack wielding something on to close up the hole. the rest of the shield is fine
Finally fixed
ok so the procedure with the plate was to cut it and slide it out which I've seen othe posts on here showing details of how's it's done. The plate was replaced but still had the noise and as previously thought it was the handbrake cable on the prop shaft. A half hour job of removing the heat shields underneath and strapping up the cable away from the prop shaft and pow no more irritating noise 👍
Really easy to do as long as the car is up in the air, and the exhaust isn't hot 😂😂😂
