4matic sway bar DIY?
Anybody knows if there is a DIY sway bar replacement for the 4matic somewhere? WIS indicates that engine mounts AND driveshafts need to be removed. I can live with removing the engine mounts and lifting the engine but the drive shafts are a real PITA.
Thank you.
Thank you.
Is it so different on 4 matic?
Easy on 2 wd.
So, no sorry, no idea.
Easy on 2 wd.
