2002 MB C320 Won't start, fans runs!
2002 MB C320; I have been chasing a battery drain problem which I have not solved yet. Removed all fuses and relays, unplugged seat motors etc. I gave it a rest for a couple of days, with the battery disconnected so it would not drain out. Went back to it now it will not crank over and the fan runs on high speed when trying to start it. I removed the ECM looked inside it and it had some minor corrosion which I cleaned up. Still the same problem! Any suggestions?
https://mbworld.org/forums/c-class-w...ull-speed.html
http://www.mercedesmedic.com/mercedes-wont-start/
and may be...
https://www.autohaussouthbay.com/201...at-wont-start/
Good luck
Generally when you have no communication with the engine control module, the fan will run on high. There is a good chance that whatever caused the corrosion on your ECM circuit board, also shorted out and killed the ECM.
