General Calliper Question
The slider pins are fine. I swapped those from the good (right) one to the left one. Same result.
I was told that the slider pins have a tendency to 'wear out' the callipers, i.e. the holes in which the pins are located become loose over time. Why and how, i don't know.
So my question is:
Can the 'loose hole' in the calliper be repaired?
Like for example, fill in the holes and then drill them back again so that the pins will fit perfectly. I was also told that it had to be a very precise job.
Thanks for the info.
once I noticed a noise and a front calipers was loose.
Pulled the wheel, reached around and the tightened the bolts,
all done.
Moral of the story is to use locktite, but I didn't.
But I should have.
Anyway, i'll have a look during the weekend.
Thanks.
Indeed, indeed!
And locktite blue just to be sure.
On a side note, my dad just replace both rear Stabiliser Link Bars on his W203. Most of the rear noises disappeared. One of the bushings was gone. I was thinking of changing the bushings on both Link Bars and putting them on mine.
Can i re use the link bars or should i replace them with new ones when the time comes?
I change the rear suspension, front stabiliser link bars and the front sway bar bushings. Tested the car today and ALL the noises were gone!!!
It looks like the stabiliser link bars or the sway bar bushings were the culprits. The ride feels really smooth and comfortable now.
Thanks guys.
