M271 normal cruising temperature
Old Feb 5, 2018 | 04:38 AM
dimgia's Avatar
Registered User
cl203 c200 m271
Hi
I have just bought a w203 coupe with m271.940 engine.
When i'm in the town my temp gauge shows the temp a little bit over 80c. When I'm in highway cruising falls where the image shows, maybe a little bit lower. I thing this is not right. Maybe a stuck open thermostat? What's your thoughts?
Old Feb 5, 2018 | 02:09 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I dont think that is correct either. How long does it take to get to 80?
Old Feb 5, 2018 | 03:37 PM
Russell Ormerod's Avatar
not a merc
Looks a bit low, I would replace the thermostat
Old Feb 6, 2018 | 02:07 AM
dimgia's Avatar
Registered User
cl203 c200 m271
I think it takes about 10 minutes. I will check it today for sure. The 10m minutes is when I start the car and ride it. I will check the time when only idle
I have bought thermostat and coolant but before replace it I wanted another opinion.
Old Feb 6, 2018 | 08:03 AM
insame1's Avatar
I do believe you are on the right track. I just have not seen this issue before on a MB. If it takes a long time to bring to temp on startup under normal temperatures then I would agree that it is the thermostat. If you already bought one you might as well put it in.
Old Feb 7, 2018 | 04:05 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
The thermostat may be bad, but when mine failed, the car threw a CEL on top of indicating a temperature around 70C like yours. Just keep an eye on it. I think the only things affected by a low operating temperature are emissions and fuel efficiency. It won't kill your car.
The thermostat is easy enough to replace. 2 bolts in the front of the engine. Be sure to have a jug of coolant handy as 2L or so will gush out.
I agree with the others that the car normally warms up to 85-90C during normal operation.
Old Feb 10, 2018 | 08:45 PM
dimgia's Avatar
Registered User
cl203 c200 m271
Hi guys
As expected the thermostat was stuck open.The thermostat I bought was a mahle but inside was a wahler as the genuine mercedes. Now it goes 80c quickly. Thanks for help
