Refilling radiator after reinstall
Hey guys...
Do I just fill the system through the reservoir?
First time working on one and not having a cap on the rad is confusing. Thanks!
Yes, just fill it through the reservoir with MB approved coolant. The hardest part is trying to bleed the system after refilling unless you are using an Air-Lift system. Fill the coolant and let the engine warm up for a few minutes. Top off the reservoir and then drive the vehicle around for a few minutes with the heat on max. Park the car and wait for 5-10 minutes and then top off the reservoir again as needed.
